1992 Toyota Camry Repair Question
Topics covered: Air filter, Fuel filter, Spark.
Asked on September 23, 2007
92 camry 3.0 sluggish
I have 92 3.0 xle automatic trans. about 150.000 miles that has become sluggish on acceleration but once underway the car seems fine ,did replace the fuel filter but that didn,t fix the situation. Do you know what could cause this problem?
Answer
Replied on September 25, 2007
what about your other tune up parts? if your buyin auto zone parts dont bother
I did change my plugs and wires last year and I changed my air filter the other day and i use Orielley parts . Had the a/c changed over to r-134 and they replaced the expandtion valve recently but i can't link it to any thing they may have done, it is the coldest a/c i have every had .
Replied on September 26, 2007
to me some aftermarket parts are ok, on a toyota, but plugs and wires, needs toyota parts, they just hold up better, after market wires dont last, check the coil also, sparks jump to coil burring it with bad wires on a 4 cylinder use a mirror after removing the dist cap
