front defroster not working
1999 TOYOTA CAMRY
75,000 MILES
ANONYMOUS
when I turn on my front defroster it blows out the dash vents and not the defroster vents but the back defroster works fine
Nov 9, 2012 at 11:35 PM
  • CAR REPAIR CONTRIBUTOR
  • 54,354 POSTS
this sounds like you have a defroster air door actuator that is not working and needs to be replaced, Here is a guide that will give you an idea of what you are in for when doing the job.
https://www.2carpros.com/articles/replace-blend-door-motor'
REMOVE THESE PARTS:
No.1 lower instrument panel
LH instrument lower panel
2. REMOVE SERVOMOTOR
Release the claw and pull out the plate.
Disconnect the connector.
Remove the 3 screws and servomotor.
INSTALLATION
1. INSTALL SERVOMOTOR
Install servomotor with the 3 screws.
Connect he connector.
Install the plate, then restraint the claw.
Insert the drain of plate to the lever pin.
2. INSTALL LH INSTRUMENT LOWER PANEL
INSTALL NO.1 LOWER INSTRUMENT PANEL
Here is the location for your car (below)
Cheers, Ken
Nov 20, 2017 at 11:50 AM
MIRACLE2011
My defrost controls are not working properly what can i do
Nov 20, 2017 at 12:01 PM (Merged)
CARADIODOC
  • 34,309 POSTS
Hello.
Here is a guide that will help
https://www.2carpros.com/articles/air-vents-stay-in-the-defrost-position
TALIALINELLE4
My ac will blow out of every vent but the front two. When I got my oil changed it started working. This morning I turned on the defrost and now it doesn't work again. What could it be ? When it started working again it was spitting stuff at me. I would like to try and fix it myself if possible otherwise it'll just stay broken. Please help.
  • 110,190 POSTS
Have you checked for vacuum leaks to the HVAC system?
TALIALINELLE4
No? How would you go about doing that?
  • 110,190 POSTS
If you are lucky, you may hear a whistling sound if there is a leak. Under the dash, you will see vacuum hoses. Just make sure none are broken or disconnected. Also, there is a supply hose from the engine. Make sure it is good.
BEATRICE JONES
Air Conditioning problem
2000 Toyota Camry 4 cyl 160000 miles
my AC, heater, defroster will only (work)blow on hi
a very very little come out other setting
Thank you
Nov 20, 2017 at 12:02 PM (Merged)
WRENCHTECH
  • 20,761 POSTS
That is nearly always caused by a bad blower motor resister. It's located under the dash on the passenger side, in the blower housing and next to the blower motor.
2CP-ARCHIVES
  • 4,540 POSTS
front window defrost procedure
procedure for what??????????????
MARKKALY
92 camry defroster switch staying on bi-level no matter what position is selected. any repairs available
WRENCHTECH
  • 20,761 POSTS
The mode doors are operated by an electric actuator that controls air direction. There can be a problem with the door jamming, the actuator itself or the control head that controls it.
LKPOWELL
I have a nasty smell coming throug the derost vents and also have a funky film on my windshield down around the defrost vents...
Dec 3, 2019 at 3:10 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi lkpowell,
Check for low coolant level in radiator. Symptom indicates a leak in the heater core and coolant level should be low.
FLYT_PM
Just bought the car,they think the A/C compressor is locked up. Checking out heater and defroster and they only blow cool air. Temp control is in hottest position. Gotta get car ready for my daughter.
Thanks in advance
  • 31,937 POSTS
Hi there,
Thank you for the donation,
These cars have a problem with the heater control unit, if the slider on the dash feels stiff, dose not move all the way or is very loose, the control cable or the control is faulty, check the heater tap to see if it is opening or closing, if it is moving the heater tap will be faulty.
Mark (mhpautos)
