Mechanics
LINED UP TIMING BELT
1998 Toyota Camry
Engine Mechanical problem
1998 Toyota Camry 4 cyl Front Wheel Drive Automatic 98,000 miles
How do you line up a timing belt?
Dynamex616
December 29, 2009.
Hi there, see pics for timing marks, do not turn engine or cam with belt off as this is an interference engine.
mark (mhpautos)
http://www.2carpros.com/forum/automotive_pictures/61395_Graphic_139.jpg
http://www.2carpros.com/forum/automotive_pictures/61395_Graphic1_14.jpg
Mhpautos
Dec 29, 2009.
Thank you for the help, I understand the bottom pic but I dont understand the top pic. The holes suppose to match up with what?
Thanks again
Dynamex616
Dec 29, 2009.
There is a line pressed into the tin backing plate, this should align with the hole.
Mark (mhpautos)
Mhpautos
Dec 29, 2009.
I lined up the timing belt for the car, but the car just doesnt seem to run. Is there another way to place the timing belt? Or at least start the car?
Thanks again
AD
Dynamex616
Dec 30, 2009.
Also the cam shaft in the upper level has to match with what line?
Dynamex616
Dec 31, 2009.
Where r the marks for the first picer
Joey sanchez
Mar 25, 2012.
Dase the whater pump have a mark to
Joey sanchez
Mar 25, 2012.
AD
