1992 Toyota Camry Repair Question
Topics covered: Gas, Stalls, Air filter.
Asked on January 6, 2008
1992 Toyota Camry stalling
i have a 92 camry and when its cold it starts up and runs fine, then when i turn off i cant get started without giving it gas, and when i let up on the gas it stalls out. gotta wait until the engine is cold again any suggestions?
Answer
Replied on March 3, 2008
I have the very same problem with my 1990 camry . I have spent 10 hours on it. filter ok,fuel pressure at filter ok, next step is to check resistance across each injector as described in haynes repair manualwith ohm meter.(air flow meter electrical plug is attached to your air filter housing) Keep trying and good luck.My question is in forum (90 camry stalls) still unanswered.Keep in touch,DESPERATE,AYLMER,Quebec!!!!!!!!!!
