No spark?
DEDEAUX1
  • 1992 TOYOTA CAMRY
Electrical problem
1992 Toyota Camry 6 cyl Automatic 80,000 miles
have 1992 toyota camry 6 cylinder, car cranks but wont start, has been sitting unstarted for about 3 yrs, have changed coil and ignitor but still get no fire from coil to distributor, could ecu or crank sensor be bad..
Friday, April 4th, 2008 AT 4:19 PM
MASTERTECHTIM
  • 4,749 POSTS
These are hard to pin point. ecu and crank sensor can cause this. i imagine you have thoroughly checked fuses and battery connections. does the check engine light come on when you turn on the key? is there power at the ignition coil?
get back to us
Friday, April 4th, 2008 AT 5:07 PM
DEDEAUX1
1992 toyota camry. All electrica circuts are clean and tight, but it does't look like a signal is being sent to the igniter, which is brand new
Friday, April 4th, 2008 AT 6:27 PM
If the computer don't get the Ne and G signals it will not give an Igt signal to the ignitor telling it to fire the coil, further NO Igf signal to the computer tell it that combustion has occured-Therefore end of result no secondary surge to the plugs.
Check the pick up coils resistances-
Tuesday, April 15th, 2008 AT 6:38 AM
STUBBY154
  • 1991 TOYOTA CAMRY
  • 4 CYL
  • 214,838 MILES
My 91 toyota camry ain't getting no fire to the coil and yes I have checked the igniter it's got power
an I have changed all the fuses
Sunday, August 2nd, 2020 AT 11:22 AM (Merged)
If its getting battery voltage to the coil -Check the coil's primary and secondary resistances and the distributor pick-up coil if okay -You're looking at the Ignitor.
BRANTLEYJ
  • 1991 TOYOTA CAMRY
  • 2.0L
  • 4 CYL
  • FWD
  • 143,000 MILES
My car ran great and then all of a sudden cranks great but does not turn over. I checked for spark, no spark. I have replaced multiple things spark plug boots wires, distributor cap rotor and all and still no start checked all fuses all are fine.
Sunday, August 2nd, 2020 AT 11:23 AM (Merged)
CARADIODOC
  • 33,752 POSTS
The parts you listed will not suddenly cause loss of spark to all cylinders. The better suspects are the ignition control module and the pick-up assembly in the distributor.
BRANTLEYJ
I have replaced the ignition control module and I am assuming it is the brain or the crank position sensor, but I am not sure.
CARADIODOC
  • 33,752 POSTS
Your engine does not use a crankshaft position sensor; at least I do not see any reference to one. That just leaves the pick-up assembly in the distributor. Engine computers do not really cause many crank/no-starts. If you have access to a scanner, you can watch the live data display to see if the computer is getting signal pulses from the distributor.
KETCHUP420
  • 5 POSTS
  • 1991 TOYOTA CAMRY
  • 260,000 MILES
Would replacing the engine relay fix the no spark to the spark plugs?
HELP!
FIXITMR
  • 9,990 POSTS
What have you done to try and fix so far?
KETCHUP420
  • 5 POSTS
Nothing yet, we dont know why there is no spark to the engine.
FIXITMR
  • 9,990 POSTS
What's the engine size/#
KETCHUP420
  • 5 POSTS
4 cylinder automatic.
FIXITMR
  • 9,990 POSTS
Have you checked for 12v at coil terminal plug with ignition on? Did you remove distributor cap and crank over to see if distributor is turning? If not the timing belt is broke.
FIXITMR
  • 9,990 POSTS
Also You should have a little grey box under the hood on the driver's side fender. If you open it up and look under the cap, it'll give pin names. The two you want to short (connect) together are TE1 and E1. Connect (bridge) those, turn engine to ON (but do not start it!) And it will blink codes. Flashes followed by pauses. They re 2 digit codes.
BERETTAGT
  • 1990 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • MANUAL
  • 178,954 MILES
My car recently I had jumped with a piece of metal my EFI fuse and had been driving it about 180 miles and all of a sudden it just had no power and burnt out a couple fuses I replaced all the bad fuses and all my fuses are working now but my car will still not start and is not getting a spark for some reason I replaced the cap and rotor brand new less then 300 miles on them was wondering if you knew where I should look to figure out why its not getting a spark if theres maybe a wiring diagram I could look at.
Check the ignition fuse/look for power at the coil/test the resistances of the distributor pick-up coil/ignitor-
BERETTAGT
Ignition fuse is getting power,
How would I check to see if the coil is getting power to it?
Remove the distributor cap and test coil positive terminal to ground-see below
https://www.2carpros.com/forum/automotive_pictures/12900_dizzy_1.jpg
