2CarPros - Car Questions & Answers
1990 Toyota Camry Repair Question
Topics covered: Spark, Engine, Coil pack.
Asked on October 10, 2008
1990 Toyota Camry no spark
Electrical problem
1990 Toyota Camry 6 cyl Two Wheel Drive
car won' start . my daughter stoped at a stop sign and the car died it started again went about 200 feet and died again . now it has no spark I do not know if it is getting fuel.
Avatar Asked by kent palmer
Answer
Replied on October 10, 2008
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Tiny Answered by rasmataz
68 questions asked
