Serpentine belt diagrams please?
2009 SUZUKI XL7
52,000 MILES
ANONYMOUS
How can I get a diagram for the serpentine belt. The belt broke and is no longer there.
Mar 8, 2013 at 10:02 PM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
this just says xl7 and doesnt' give engine size. but specs ay it's what you are looking for. also replace the belt tensioner as well.
Mar 8, 2013 at 11:57 PM
SUZUKI07
  • 19 POSTS
Does anybody have the diagrams on how to change the timing chains on my car listed above it has the 3.6L V6 SFI DOHC 24V?
Aug 27, 2020 at 12:48 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Here are the diagrams for the timing marks.
SUZUKI07
  • 19 POSTS
Thanks a lot....................
KHLOW2008
  • 41,814 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
  • 54,350 POSTS
Here is the serpentine belt diagram (below):
Cheers, Ken
JACKIEFISHER
  • 5 POSTS
My vehicle has noises from the engine area since early spring. Especially upon a cold start the engine has this zzzzzzzz sort of sound when climbing or accelerating. ATF and spark plug change did not fix it.
This video has all the noises. First ones sounds like belt noise. Later recordings are from the car accelerating, especially cold start:
https://www.youtube.com/watch?v=tfHxoxeLoYA
Many thanks for any ideas you may have!
  • 110,190 POSTS
Welcome to 2CarPros.
Honestly, it sounds like the power steering pump. Does the sound change when turning? Have you remove the belt and started the car for a couple seconds to see if the noise is gone?
Listening to the video, I suspect either the power steering pump or the alternator is making noise. If you have an automotive stethoscope, see if that is where the noise is coming from and let me know.
Also, I would remove the belt and start it for a couple seconds just to see if the sound is gone. At that time, I would check each of the belt driven accessories for bearing issues.
Let me know,
JACKIEFISHER
  • 5 POSTS
Thank you very much for the timely and informative reply, Joe! I have not done anything with the serpentine belt; the only reason I suspected it was reading of online posts, and the noise at idle. I try fix my own toys but I am very ignorant at this stage. Did you think the belt is any likely to be the culprit at all without considering my poor guess?
About noise when turning, generally no, except [1] I have heared the same noise as expected from accelerating, when turning left at intersections, but you know I had to press the accelerator in these cases:) [2] occasional squeaking from the steering wheel when I am frantically parking.
Tldr I did not find any correlation in that “ engine “noise and steering action.
The noise upon acceleration was worse earlier in the year when it was colder, but still shows occasionally now. (( Back then the engine power also felt inadequate simultaneously, hence the plug and ATF change at 150,000 km. Power issue was fixed but noise remained)). I drove to my mechanic 15,000 away one morning and by the time I reached him the noise was all gone.
  • 110,190 POSTS
Welcome back:
First, check to make sure the power steering fluid is full. As far as the belt itself, it sounds like a whine in the video, and a belt, in and of itself, won't do that. I think you have a bearing going bad in one of the components or the power steering fluid is low. If you can, carefully check using an automotive stethoscope to see if you can hear which component is making the noise. Or, remove the belt and start the engine only for a couple seconds to see if the sound is gone. If it is, then check each of the belt driven accessories to make sure there isn't a bearing going bad in one of them.
By the way, you can get a stethoscope at any parts store. They are very inexpensive. Usually under $10.00. Just be careful when using it not to touch any moving parts.
Let me know what you find.
JACKIEFISHER
  • 5 POSTS
Thanks Joe!
Today I went to local mechanics chain because the disassembly looks daunting to me. By the time I drove to the place (10-15 minutes) the noise was gone and after looking at it for an hour including test drive the mechanic found nothing and said "come back when it's actually noisy" (lol) and suspected one of the engine fixtures was loose.
Guess I'll have to wait for a cold morning with stethoscope.
  • 110,190 POSTS
Welcome back:
It seems when something is warming up, the noise goes away. The stethoscope is the best way to identify where the noise is coming from. See that, you'll be a doctor of motors. LOL
If you can, please keep me in the loop so I can help. Feel free to ask as many questions as you have.
JACKIEFISHER
  • 5 POSTS
Yes for sure, and my thanks for that!
JACKIEFISHER
  • 5 POSTS
Would you think it's the engine oil? it is not due for a change but it's dark brown, smell burnt a little, and only just reaches above the lowest of the three holes on the stick.
  • 110,190 POSTS
Welcome back:
No, as long as the oil is in the safe range, you are fine. Also, it wouldn't cause this type of noise.
2CP-ARCHIVES
  • 4,540 POSTS
Is there a routing diagram for the serpentine belt?
  • 54,350 POSTS
Here is a guide to help you see what you need to do when replacing the serpentine belt step by step with a diagram below to show you on your car.
https://www.2carpros.com/articles/replace-serpentine-belt
Check out the belt routing diagrams (Below) Please let us know if you need anything else to get the problem fixed.
GARY42
how do I adjust power steering belt?
DAVE H
  • 13,384 POSTS
https://images.2carpros.com/forum/automotive_pictures/266999_xl_1.jpg
BARB BENWAY
The alternator belt broke now cannot see how it goes on. It will not go on the very last pulley because the timing chain thing has a metal little plate hanging over. the belt will not fit under that . Do you have a picture of what pulleys it goes on? It is not a big belt.
HMAC300
  • 48,601 POSTS
if replacing belt replace tension-er as well move in direction of arrows alternator belt has a nut on top bottom that have to be loosened then tightened after replacing and adjusting belt. See picture.
SUEZQ
Electrical problem 6 cyl Four Wheel Drive Automatic 98000 miles
I need instructions on replacing the alternator belt on my suzuki. The belt shredded and came off, my son-in-law tried to put the new one on but didn't know how. I am a widow on a fixed income so I hope one of your members can help me.
Aug 27, 2020 at 12:49 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
REMOVAL: Disconnect negative cable at battery. Loosen tension pulley bolt and tension pulley adjusting bolt. Remove Water Pump and alternator Drive Belt. Here are guides to help you get the job done https://www.2carpros.com/diagrams/suzuki/xl-7/2002 and https://www.2carpros.com/articles/replace-serpentine-belt
https://images.2carpros.com/forum/automotive_pictures/261618_0996b43f80207449_1.jpg
