transmission fill and service
2004 SUZUKI VERONA
KYRIEGARCIA
where is the transmission filter, and where can I find the plug remover/installer tool for the fluid to buy or rent?
May 6, 2011 at 6:47 PM
DOCFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 18,828 POSTS
Trans has no filter to change just fluid . see diagrams think 3/8 drive will fit. Here is a guide that will help with diagrams below to show you on your car
May 6, 2011 at 7:06 PM
EDGURO
hello.....my transmission is seal and has warranty for 100k miles but it expired...now radiator is leaking and need to replace it....as a result...i want to fully change transmission fluid too.....can you help...thank you.....
Apr 4, 2019 at 1:41 PM (Merged)
DRCRANKNWRENCH
  • 3,380 POSTS
Attached are instructions for fluid change and level check.
EDGURO
thank you....you guys are awesome...
DRCRANKNWRENCH
  • 3,380 POSTS
Your very welcome.
come back anytime for questions or even advice as we have a great team of techs ready and willing to help.
Take care
Dr. C
Apr 4, 2019 at 1:42 PM (Merged)
VEUXBAGNOLE
Transmission problem 6 cyl Front Wheel Drive Automatic
Where do you fill the transmission? There is no dipstick (besides the guy driving the car) I love this site.
  • 54,354 POSTS
Hello, You will need to raise the car up safely. https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely Here is how the manual give you instructions (below) CHECKING FLUID LEVEL Start the engine and allow the engine to idle for approximately 5 minutes, or , if possible, drive the vehicle for a few miles to warm the transaxle fluid. Check the fluid level when the transaxle is over 86 °F (30 °C). Press the brake pedal and move the shift lever through the gear ranges, pausing a few seconds in each range. Return the shift lever to the park position. Raise and suitably support the vehicle. Place a fluid container below the fluid level plug. WARNING:Do not remove the fluid level plug if the transaxle fluid is hot. This may cause injury if the fluid drains from the plug hole. Remove the fluid level plug using the plug remover/installer. Because the transaxle operates correctly over a range of levels, fluid may or may not drain out of the plug hole when the plug is removed. Check the oil fluid level. If fluid does not drain through the plug hole after adding a total of 4 liters, the transaxle was either underfilled or it is leaking fluid. Inspect the transaxle for fluid leaks. Fix any leaks before setting the transaxle fluid level. See Fig. 5 . Install the fluid level plug using the plug remover/installer. Tighten the plug to the specifications. When the fluid level checking procedure is completed, wipe any fluid from the transaxle case with a rag or shop towel. Also, check that the fluid fill cap and the vent tube are properly installed.
https://images.2carpros.com/forum/automotive_pictures/266999_5_11.jpg
(Check out more diagrams below) Please let us know if you need anything else to get the problem fixed. Cheers, Ken
