Where are the Camshaft Sensors located?
2016 SUBARU LEGACY
103,000 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
SABRTYCA
Needing to replace both bank 1 and, bank 2 camshaft sensors. So far, after hours of searching Google and, the Tube, I have yet to find any clear answers or schematics for a 6 gen Legacy.
Apr 16, 2023 at 4:25 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
If you look below, pic 1 shows an exploded view of the engine/sensors. Pic 2 is the legend for the picture.
There are a total of 4 cam sensors on this vehicle. Two are for each exhaust camshaft and the other two are for each intake camshaft.
Let me know if this helps. If you do need wiring schematics, let me know.
joe
Apr 16, 2023 at 9:15 PM
SABRTYCA
Driver pic 1 Pass pic 2... Are these the bank 1 and, bank 2 sensors?
Apr 17, 2023 at 9:05 AM
  • 110,190 POSTS
Those appear to be the sensors. Have you had a chance to replace them?
Apr 18, 2023 at 6:43 PM
2CP-ARCHIVES
  • 4,540 POSTS
where is the camshaft positioning sensor located?
Jun 21, 2023 at 1:01 PM (Merged)
KHLOW2008
  • 41,814 POSTS
The camshaft position sensor is located on the left side if the engine near the front. Here is a guide and diagram to help you see how to do the job check out the diagrams below.
https://www.2carpros.com/articles/camshaft-angle-sensor-replacement
CHITJ
Diagnostic scan showed camshaft sensor & engine sensor faulty. Replaced both. However, when the aircon/heater button is pressed ON, the red warning light pops up and the engine runs differently.
Jun 21, 2023 at 1:02 PM (Merged)
  • 31,937 POSTS
Hi there,
Thank you for the donation,
I would be doing a continuity 7 resistance check down the loom from these sensors to the ECU and check that the plugs (loom ) have not got loose or corroded pins, start here.
mark (mhpautos)
