Camshaft position sensor location?
ANONYMOUS
  • 1997 TOYOTA 4RUNNER
  • 358,840 MILES
How to replace cam sensor?
Sunday, February 10th, 2013 AT 6:09 PM
KHLOW2008
  • 41,814 POSTS
Removal & Installation
1. Camshaft position sensor is located behind upper timing belt cover, near passenger's side camshaft sprocket. See Fig. 4.
2. Drain cooling system. Remove upper radiator hose. Remove necessary components for removal of upper timing belt cover. Remove bolts, upper timing belt cover and gasket. Remove bolts and camshaft position sensor.
3. To install, reverse removal procedure. Fill cooling system.
Sunday, February 10th, 2013 AT 8:58 PM
EDROSE
  • 4 CYL
  • 4WD
  • 188,000 MILES
Location of the cam position sensor?
Wednesday, December 23rd, 2020 AT 1:09 PM (Merged)
WRENCHTECH
  • 20,758 POSTS
It's located in the side of the head as shown in the bottom of the picture. Check out the diagrams (Below). Let us know what happens and please upload pictures or videos of the problem.
https://www.2carpros.com/images/external/79028252.gif
JLOBAINA
  • 18 POSTS
  • 1992 TOYOTA 4RUNNER
I am working on this vehical and need the location of the camshaft sensor I need to change it; can you tell me where the canshaft sensor is located on this vehical?If possible can you send me a diagram? Will apreciate you have been very helpful to me with past questions.
JDL
  • 16,098 POSTS
I'm not sure of engine litre size?
JLOBAINA
  • 18 POSTS
Its a v6 3.0 efi
JDL
  • 16,098 POSTS
The info I looked at was for 3.0L.
I'll double check that on a different database.
JLOBAINA
  • 18 POSTS
Thk u let u kno how it works out
JDL
  • 16,098 POSTS
My other databases didn't show a cam sensor, showed a distributor. That was the only picture I found. Some of the text said, front of right cylinder head.
JLOBAINA
  • 18 POSTS
Your first respond was a big help I finished the job thank you for your accuracy.
JDL
  • 16,098 POSTS
Glad you got it going your way.
