2008 Saturn Outlook Repair Question
Asked on October 15, 2009
2008 Saturn Outlook headlight
Electrical problem
2008 Saturn Outlook 6 cyl Front Wheel Drive Automatic 62000 miles
how do you replace a headlight bulb?
Answer
Replied on February 12, 2010
unfortunately the headlamp bulbs are not an easy task in the outlook, plus they are having a problem with the connectors to the bulbs melting. to gain access to the headlamp bulb your suppose to remove the front bumper cover assembly, then the headlamp, but I have had some luck with just removing the plastic wheel liner that is with in the wheel opening and reaching up to the headlamp to get the bulb.
