Mechanics
REPLACE HEADLIGHT
2007 Saturn Outlook
Electrical problem
2007 Saturn Outlook 6 cyl All Wheel Drive Automatic
How do you replace a headlight on a 2007 Saturn Outlook?
Saturndriver
November 15, 2008.
Unfortunately the headlamp bulbs are not an easy task in the outlook, plus they are having a problem with the connectors to the bulbs melting. To gain access to the headlamp bulb your suppose to remove the front bumper cover assembly, then the headlamp, but I have had some luck with just removing the plastic wheel liner that is with in the wheel opening and reaching up to the headlamp to get the bulb.
Basstech
Feb 12, 2010.
