Power Door Lock
SEAN56321
  • 2001 TOYOTA CELICA
  • 4 CYL
  • FWD
  • MANUAL
  • 136,000 MILES
The passenger side power door lock is being temperamental. Sometimes, the power lock will lock/unlock the door and sometimes it will not. Sometimes, it will properly lock/unlock a second or two after the driver side door works. When it doesn't work, the manual lock switch still moves, it just moves less than when it locks appropriately. This is true of both the wireless and interior lock button. The door will lock and unlock just fine if done manually or with a key.
Sunday, November 29th, 2009 AT 8:32 PM
MMPRINCE4000
  • 8,549 POSTS
It sounds like you have a lock actuator that is not working. I would remove the door panel and use a test light to confirm it is getting power when you use the switch.
Here is a diagram to help us.
Please let us know what you find.
Cheers
Monday, November 30th, 2009 AT 7:40 AM
SEAN56321
Yep it was the latch I found the part for 48.00 bucks and replaced it now anything works great thanks again I love this site.
Monday, November 30th, 2009 AT 8:50 AM
MMPRINCE4000
  • 8,549 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers
Tuesday, December 1st, 2009 AT 7:44 AM
RONMAN71
  • 1.8L
  • 4 CYL
  • FWD
  • 126,000 MILES
Both the power windows and power locks will not work at all. I am guessing the switch in center console since it works both? I have checked fuses and all seem fine. Sunroof and other interior items working fine
Tuesday, March 13th, 2018 AT 3:36 PM (Merged)
  • 108,269 POSTS
Have you checked for power to the switch?
RALPHDEGUZMAN
  • 2000 TOYOTA CELICA
  • 4 CYL
  • FWD
  • 126,000 MILES
Electrical problem
2000 Toyota Celica 4 cyl Front Wheel Drive Automatic 126000 miles
2000 celica with power doof lock problem. The drivers side power locks does not work. It has keyless entry. When the doors are unlocked the drivers door doen't unlock. It has to done manually.
Thanks for the help.
KHLOW2008
  • 41,815 POSTS
Hi ralphdeguzman,
Check for a faulty door lock actuator or open wiring circuit.
