ABS light
2007 PONTIAC MONTANA
101,000 MILES • 6 CYL • 2WD • AUTOMATIC
SUSAN J
The warning light for ABS, Traction control keeping coming on, and car "jumps" a bit when I put foot on gas pedal when at stop light for instance, thats when the warning light usually comes on,
Has anybody else had this problem?
Feb 10, 2011 at 4:20 AM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
This is common when the front bearing hubs start to go out causing the sensor to stop working but to be sure this video shows how to get the codes.
https://youtu.be/rTtAnsOlZU4
Mar 10, 2011 at 4:52 PM
NCKELLY83
  • 0 POST
I got a new right front bearing hub fixed my car. cost me $132.00
Dec 4, 2019 at 4:57 PM
BRIWEN
after replacing front and rear brake pads, The brakes are working fine. The rotors did not need replacing. Calipers were free and not leaking.Levels are correct.The ABS light remains on. How do I reset this light?
Please help me with this annoying dilemma
thanks, brian.
Dec 4, 2019 at 4:57 PM (Merged)
JUSTBROWSING
Thats good, but there is still something wrong with your Antilock Braking System. Possibly a bad wheel speed sensor or corroded electrical connection? If this light started coming on only after your brakes were worked on, go back to the shop and have them check whether they disconnected a sensor. Otherwise, have it looked at by Mr. Goodwrench.
2CP-ARCHIVES
  • 4,540 POSTS
I had my front brakes repaired at a garage and now the brake light, not the ABS light, comes on. Any idea why?
HMAC300
  • 48,601 POSTS
it could need bleeding or a bad master cylinder.
HMAC300
  • 48,601 POSTS
parking brake could be on as well
MIKEDEES
yesterday I braked on a dry non slippery surface and the ABS brakes engaged and then the ABS light came on.
Since then the ABS light is not on, but the ABS did engage one more time while I was stopping.
  • 110,190 POSTS
Chances are there is a problem with one of the sensors at a wheel. What I recommend is to have the computer scanned for codes. If the light was on, there should be a code stored in the computer that would identify where the problem came from.
Most parts stores will do it for free, so I recommend having that done and let me know what you find.
SIMPLYGRAMPS
The ABS light comes on sometimes while I am driving. It also occasionally makes a whirring sound, sometimes when I apply my brakes and sometime when I first start to drive. After I get the speed up beyond fifteen mph, I do not hear the sound. However, sometimes, at very low speed, when I apply my brakes, there is a thunking sound and sometime even a chatter and it does feel like it wants to stop moving. Then it goes away and may not happen at all that day, unless it sits still for a couple of hours and it starts all over again. I was told that it was the left side front wheel hub so it was changed, yet it still does the same.
MMPRINCE4000
  • 8,548 POSTS
You need to get ABS system scanned with chassis scanner. Most auto parts stores only scan power-train codes, so you will have to find a shop that can scan ABS system and isolate problem.
Here is a video that show you how:
Cheers, Ken
KTBANDD
Hey, I have the same problem. I have replaced both sensors on the front tires and had countless other scans. How did you fix yours? Thanks, Dana
Dec 4, 2019 at 4:58 PM (Merged)
MMPRINCE4000
  • 8,548 POSTS
The ABS scan should point the tech in the right direction, it may also be the ABS computer/traction control system.
BELLC
So, what is the solution? Is this is a manufacturer's defect? I have the same problem.
FITTER63
Brakes problem
2001 Pontiac Montana 6 cyl Front Wheel Drive Automatic
How can I read the codes for a 2001 Montana for the ABS light. Also, do you know a code website that has the codes and what they mean?
F4I_GUY
  • 3,302 POSTS
A few local parts suppliers will scan your vehicle for free. Or you may purchase a code reader that is GM ABS compatible for your year. With a scantool or code reader the full DTC will appear, so you will know which circuit is at fault.
Hope this helps.
  • 54,350 POSTS
This is a problem with the ABS control module. Here is a guide to show you how to change it out you can get a new one from Amazon:
https://www.2carpros.com/articles/how-to-replace-a-abs-controller
Make sure the wheel speeds ensors are working right as well.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Please run down these guides and diagrams and report back.
Cheers, Ken
