Fuel pump access panel location
2001 PONTIAC MONTANA
98,000 MILES • 6 CYL • 2WD • AUTOMATIC
WIDTRAK77
  • 8 POSTS
Is there an access panel for the fuel pump under the carpet in my van?
Mar 30, 2009 at 10:24 AM
JAMES W.
  • CAR REPAIR CONTRIBUTOR
  • 2,394 POSTS
No, you have to drop the fuel tank. An access panel would have been a good idea, but they never did it. I have heard of people "cutting" one in, but I would not recommend it.
Here is a guide to help and diagrams below to get the job done:
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Cheers
Mar 30, 2009 at 11:39 AM
HACKEX
Six cylinder two wheel drive automatic 13,000 miles.
No codes are thrown. Engine turns over but no go. It has spark.
Jul 2, 2018 at 5:46 PM (Merged)
MERLIN2021
  • 17,250 POSTS
Grab a noid light, at the parts store, they are cheap, plug it into your injectors to see if they are firing, if they are, test fuel pressure.
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
WILLIAMRAWSON
I am wanting to know if there is a access panel for the fuel pump or do I have to drop the tank?
STEVE W.
  • 15,158 POSTS
Sorry, tank has to come down if you do it by the book. There are people who have cut the floor open but not something I recommend. Fuel vapor + spark while cutting = Not anything good!
We can hear the fuel pump running, there is fuel at the engine, but the van will still not start. If we manually inject gas at the throttle body, the van runs until this gas is burned.
BLUELIGHTNIN6
  • 16,542 POSTS
Assuming this is a fuel issue and that spark and compression are good, since the fuel is getting to the injectors but no further, you will need to test the injectors to ensure they are pulsing. If they are not, check fuses and relays. If they are then test the fuel pressure to ensure there is enough fuel being pushed through by the fuel pump.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Jul 2, 2018 at 5:47 PM (Merged)
