disabled due to theft system
2004 PONTIAC GRAND PRIX
142,000 MILES • 3.8L • 6 CYL • FWD
DOUGLAS CANNON
  • 5 POSTS
Replaced the ignition switch and ignition cylinder lock. Now message comes on saying starting disabled due to theft system.Tried the relearn process. But my message does not go off at all. Let alone after ten minutes, still will not start.
Mar 15, 2017 at 5:19 PM
CARADIODOC
  • CAR REPAIR CONTRIBUTOR
  • 34,309 POSTS
Connect a battery charger, then do the ten-minute relearn procedure three times in succession. Once will not do it. Wait for the theft system light to turn off after ten minutes, turn the ignition switch off, then back and, and wait for another ten minutes. Do that a third time, then crank the engine without first turning the ignition switch off.
This guide will help us
https://www.2carpros.com/articles/how-to-reset-a-security-system
Mar 15, 2017 at 5:48 PM
DOUGLAS CANNON
  • 5 POSTS
I will try this again.
Mar 15, 2017 at 6:01 PM
WRENCHTECH
  • 20,761 POSTS
That will not work on this one Doc. This uses transponder keys that have to be programmed.
There is an "add key" procedure but it requires an already programmed master key. When replacing the key cylinder with a different key, a factory level scan tool is required.
Connect a scan tool to the vehicle.
Turn ON the ignition, with the engine OFF.
Insure that all power consuming devices are turned OFF on the vehicle.
With a scan tool, select Request Info. under Service Programming System and follow the scan tool on-screen instructions.
Disconnect the scan tool from the vehicle and connect the scan tool to a Techline Terminal with the current Service Programming System (SPS) software.
On the Techline Terminal, select Service Programming System and follow the Techline Terminal on-screen instructions.
Disconnect the scan tool from the Techline Terminal and re-connect the scan tool to the vehicle.
With a master passkey III key, turn ON the ignition with the engine OFF.
With a scan tool, select Program ECU under Service Programming System.
At this point the scan tool must remain connected for the duration of the ten minute relearn procedure.
Observe the scan tool, after approximately ten minutes the scan tool will display "Programming Successful, Turn OFF Ignition". The vehicle is now ready to relearn the key information and/or the passwords on the next ignition switch transition from OFF to ON.
Turn OFF the ignition and wait five seconds .
With a master Passkey III key, start the vehicle. The BCM has now learned the key transponder information and the PCM has now learned the fuel continue password.
Mar 15, 2017 at 6:38 PM
CARADIODOC
  • 34,309 POSTS
Thanks Wrenchtech. This is why we are held to much higher standards than are doctors. They only have to learn two models in varying sizes. We have to relearn new models with new systems every year!
Mar 15, 2017 at 6:43 PM
DOUGLAS CANNON
  • 5 POSTS
I did not change keys. the new cylinder lock was keyed to the original.
Mar 16, 2017 at 8:41 AM
WRENCHTECH
  • 20,761 POSTS
In that case you have a fault in the system somewhere. You will need a high end scan tool capable of accessing the BCM codes. You could have damaged the sensor during the repair or maybe even forgot to plug it in.
Mar 16, 2017 at 9:56 AM
DOUGLAS CANNON
  • 5 POSTS
Thank you guys so very much car is now running.
Mar 16, 2017 at 10:19 AM
WRENCHTECH
  • 20,761 POSTS
Please post the resolution.
Mar 16, 2017 at 10:20 AM
DOUGLAS CANNON
  • 5 POSTS
Had to get a code reader and clear the dit code from old ignition.
Mar 16, 2017 at 10:23 AM
  • 54,354 POSTS
Is the car fixed now?
Mar 18, 2017 at 2:58 PM
JHARVEY51
Replaced starter on my daughter's 2004 Pontiac Grand Prix GTP. Now, car will not start and the DIC gives message "starter disabled by theft system". I have tried disconnecting battery and several other suggestions to turn car off and on waiting for security system to turn off, but they did not work. I went to three different auto parts stores, none of them had a code reader/scanner that could clear the problem.
Nov 1, 2018 at 11:40 AM (Merged)
  • 54,354 POSTS
It sounds like you got the wiring wrong on the starter. Did you get the trigger wire on the right lug becasue there are two positions and only one will work.
Here is a wiring diagram for you. (below)
Also to reset the alarm you need to remove the negative cable and touch it to the positive cable for 5 minutes, this will hard reboot the system.
Here is a starter replacement guide that can help as well
and
Cheers, Ken
TOYLADY155
how do you rest the security light on 94 Pontiac grand prix? Car starts and drives but the security light is constantly on.
JDL
  • 16,098 POSTS
Have you done anything to the security system? Any applicable trouble codes?
Maybe a short on the lite circuit?
  • 54,354 POSTS
You need to help the system relearn itself. Leave the ignition key on without starting or cranking the engine over for 10 minutes the security light will stop flashing this means the system has relearned itself and you are ready to go.
Cheers, Ken
GREENED86
how do i dissconect my alarm it will not shut off and is killing the batt.
MMPRINCE4000
  • 8,548 POSTS
Is it aftermarket or factory?
GREENED86
I believe it is a factory alarm i cannot find the brain anywhere and is is hooked to everything lights, horn, ext.
MANGO27
Computer problem
1996 Pontiac Grand Prix Two Wheel Drive Automatic
if i buy new ignition will i have to take it to the dealer to re-set the anti theft?.I was told that my anti theft sensor in my ignition went bad the car only starts if i leave the ignition in the acc position if not i have to wait 15 min. for the car to start and by that time my batt. is low from the acc...can any one help me with this ploblem?
WRENCHTECH
  • 20,761 POSTS
Here is the relearn procedure
30 Minute Re-Learn Procedure
1. Turn ON the ignition, with the engine OFF.
2. Attempt to start the engine, then release the key to ON (vehicle will not start).
3. Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn OFF.
4. Turn OFF the ignition, and wait 5 seconds.
5. Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes ( the vehicle is now ready to relearn the Passlockâ„¢ Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK).
Important
The vehicle learns the Passlockâ„¢ Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
6. Start the engine (the vehicle has now learned the Passlockâ„¢ Sensor Data Code and/or password).
7. With a scan tool, clear any DTCs if desired (history DTCs will self clear after 100 ignition cycles).
ALCO88
2005 Pontiac Grand Prix 6 cyl Two Wheel Drive
My Grand Prix hasn't been in working condition since March because of an accident. I recently had it towed to a mechanic to get it fixed, but had to buy a new battery so it can be moved. Now the car won't start at all because of the theft lock and I don't have the key that opens the driver door it was sold to me used with only the keyless-entry remote (which I no longer have) and the ignition key. I don't have the means to pay for another key to be made. Is there any way I can unlock the car myself or disable the alarm? Please let me know ASAP the dealer will not hold the car for long if theres no way to move it!
Thank you so much
WRENCHTECH
  • 20,761 POSTS
I'm afraid it's going to require the use of a scan tool to do this.
Here is the procedure
PROGRAMMING THEFT DETERRENT SYSTEM COMPONENTS
IMPORTANT:
* When replacing a body control module (BCM) with an GM Service Parts Operation (SPO) replacement part, set up the replacement BCM prior to the 10-Minute Relearn Procedure or the 30-Minute Relearn Procedure. Refer to Body Control Module (BCM) Programming/RPO Configuration in Programming and Setup.
* When replacing a BCM with an GM SPO replacement part, the module will learn the keys immediately. The existing powertrain control module (PCM) must learn the new fuel continue password when you replace the BCM.
* When replacing a PCM with a GM SPO replacement part, the new PCM will learn the incoming fuel enable password immediately after programming and upon receipt of a password message. A PCM which had been installed in another vehicle would have learned the fuel enable password of the other vehicle's BCM. Perform either the 10-Minute Relearn Procedure or the 30-Minute Relearn Procedure to learn the fuel enable password of the current vehicle's BCM.
* When performing either relearn procedure, all previously learned keys will be erased from the BCM memory.
* Additional keys may be learned. Refer to Adding Keys (Domestic).
Use this procedure after replacing the following components:
* The PASS-Key III (PK3) keys
* The BCM
* The PCM
1. Connect a scan tool to the vehicle. IMPORTANT: If replacing a BCM with a GM SPO replacement part, perform the procedure to setup a new BCM prior to the 10-Minute Relearn Procedure. Refer to Diagnostic System Check - Vehicle in Vehicle DTC Information.
2. Turn ON the ignition, with the engine OFF.
3. Insure that all power consuming devices are turned OFF on the vehicle.
4. With a scan tool, select Request Info. under Service Programming System and follow the scan tool on-screen instructions.
5. Disconnect the scan tool from the vehicle and connect the scan tool to a Techline Terminal with the current Service Programming System (SPS) software.
6. On the Techline Terminal, select Service Programming System and follow the Techline Terminal on-screen instructions.
7. Disconnect the scan tool from the Techline Terminal and re-connect the scan tool to the vehicle.
8. With a master PASS-Key III key, turn ON the ignition with the engine OFF.
9. With a scan tool, select Program ECU under Service Programming System.
10. At this point the scan tool must remain connected for the duration of the 10-Minute Relearn Procedure.
11. Observe the scan tool, after approximately 10 minutes the scan tool will display "Programming Successful, Turn OFF Ignition". The vehicle is now ready to relearn the key information and/or the passwords on the next ignition switch transition from OFF to ON.
12. Turn OFF the ignition and wait 5 seconds .
13. With a master PASS-Key III key, start the vehicle. The BCM has now learned the key transponder information and the PCM has now learned the fuel continue password.
14. Turn OFF the ignition and wait 15 seconds minimum. IMPORTANT: Perform this step ONLY on vehicles with EXPORT configured BCMs.
15. With a second master PASS-Key III key, start the vehicle. The BCM has now learned the second master PASS-Key III key transponder information IMPORTANT: Perform this step ONLY on vehicles with EXPORT configured BCMs.
16. With a scan tool, clear any DTCs. 30-Minute Relearn Procedure Use this procedure after replacing the following components:
o The PASS-Key III (PK3) keys
o The BCM
o The PCM
1. With a master PASS-Key III key, turn ON the ignition, with the engine OFF. IMPORTANT:
o This procedure is not available on vehicles equipped with option code (Z49).
o If replacing a BCM with an GM SPO replacement part, perform the procedure to setup a new BCM prior to the 30-Minute Relearn Procedure.
2. Observe the STARTING DISABLED DUE TO THEFT message on the driver information center (DIC), after approximately 10 minutes the STARTING DISABLED DUE TO THEFT message on the DIC will turn off.
3. Turn OFF the ignition, and wait 5 seconds .
4. Repeat steps 1-3 two more times for a total of 3 cycles or 30 minutes .
5. With a master PASS-Key III key, start the vehicle. The vehicle has now learned the key transponder information and the PCM has now learned the fuel continue password. IMPORTANT: The vehicle learns the key transponder information and/or passwords on the ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
2CP-ARCHIVES
  • 4,540 POSTS
if I take my 2000 grand prix gtp to a GM service garage, will they be able to disable my passlock 2 anti-theft system?
i dont know of any reputable shop that will disarm security systems.
TENNO89
  • 8 POSTS
i'm having the same issue except i didnt replace my ignition. i have a 2006 grand grix gt. the "starting disabled due to theft system" message is showing with no security light coming on on the gauges.
i thought there might be a prob with the transponder after the previous owner broke off the top portion of the key & drilled a hole in the corner of the key so i had the dealer make me a new key.
i started the learning process & waited a bit over the 10 minutes it said. no go. the "starting disabled" message didnt disappear. i tried this step 3 times. ugh
i should mention that before starting this, i charged the battery overnight.
Jan 25, 2019 at 2:06 PM
  • 110,190 POSTS
Hi and thanks for using 2carpros.com
The system isn't recognizing the key, as you already know. Now, what that means is the power control module (PCM) isn't receiving a correct key password from the body control module.
So with that said, there should be a diagnostic trouble code stored. If possible, scan the computer and let me know what code is found.
Here is a quick video showing how a scanner is used.
https://youtu.be/YV3TRZwer8k
Now, if you tried the 10 minute relearn process is performed, all keys previously learned may be lost. That takes us to the next step. The adding keys procedure needs to be performed. However, you still need the original key to do this. Take a look through this procedure and let me know if this is what you have already done.
ADDING KEYS (DOMESTIC)
IMPORTANT:
- To initiate, this procedures requires that a learned master key be available.
- A total of 10 master keys or valet keys may be programmed to a single vehicle.
- This procedure adds keys only. The procedure does not erase previously learned keys.
- The keys to be learned must duplicate the mechanical cut of the current key.
- If more than one valet key is to be learned, immediately precede each valet key with a learned master key.
1. With a previously learned master key, turn ON the ignition, with the engine OFF.
2. Turn OFF the ignition and remove the key.
3. Within 10 seconds insert the key to be learned. Turn ON the ignition with the engine OFF. The vehicle has now learned the new key.
I hope this helps. The 10 and 30 minutes relearn procedure is used when the BCM or PCM is replaced.
Let me know what happens.
Jan 25, 2019 at 7:51 PM
MELISSA MEADE
Electrical problem
1995 Pontiac Grand Prix Front Wheel Drive Automatic
I change the battery and starter cilinode now my car wont stay running it will start and stay running for a couple of minutes and then cut out were I am not getting any power. I was told that I need to have my security system reset. Did you think that could be my problem and how do I do that?
Jan 10, 2020 at 11:36 AM (Merged)
MASTERTECHTIM
  • 4,750 POSTS
if it was a security problem the car would not start or start and immediately stall. check the fuse block under the hood and you will see a red wire going to a terminal at the fuse box. the nut on the cable to the stud loosens up and causes this problem, let us know how you make out
MARINA HOLLY
I have a 2004 Pontiac Grand Prix and recently had to replace my lock cylinder to my car because somebody broke in and ripped out the whole assembly. I had the cylinder key to the original key I have, however the cars staying disabled and won’t turn on. I don’t know what steps I should take out this way or what way is the best route for me to go. if somebody has any suggestions on the next steps I should take it would be greatly appreciated.
Apr 20, 2021 at 11:14 AM
STEVE W.
  • 15,158 POSTS
Marina, when you turn the key to on, and then to start what does the car do? Will it start and run a few seconds or does it do nothing in either position?
Apr 20, 2021 at 4:43 PM
