how do you change the serpentine belt?
1994 PONTIAC GRAND AM
VICKI46
We are having an extremely hard time trying to change the serpentine belt on a 1994 Grand Am. My brother in law has jacked up the motor, he still can't get to the belt. There seems to be a couple brackets in the way, are these to be removed? Is this as difficult as we are finding? It is a front wheel drive, he has built engines, replaced engines and never ran into this kind of a problem. Please anyone with some suggestions on changing the serpentine belt on a 1994 Grand Am would be appreciated. Thank You
Feb 17, 2008 at 9:35 AM
MERLIN2021
  • CAR REPAIR CONTRIBUTOR
  • 17,250 POSTS
there are 3 18mm bolts on the engine mount bracket. the lowest bolt needs to be coated in thread locker or pipe sealant as that bolt enters a water jacket. the belt can be serviced by jacking the engine approximately 4" after removing the transverse engine mount.
This guide will help
https://www.2carpros.com/diagrams/pontiac/grand-am/1994
Feb 17, 2008 at 9:46 AM
REG940
diagram for belt routing ,alternator
Jul 28, 2020 at 1:11 PM (Merged)
MERLIN2021
  • 17,250 POSTS
Top is 2.0 Bottom is 2.2 and 2.5
https://images.2carpros.com/forum/automotive_pictures/62217_Belt20_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_Belt22_1.jpg
REG940
I got the routing diagram for the 94 grand am, but this model is the 2.3L. the belt only drives the alt. crank, a\c. Thanks
Jul 28, 2020 at 1:12 PM (Merged)
MERLIN2021
  • 17,250 POSTS
Why did't ya say so? Voila!
https://images.2carpros.com/forum/automotive_pictures/62217_Belt23_1.jpg
ICED84
What would make my 93 4 cyl. quad grand am shred the serpentine belt immediatly when I put one on?
NICKYD01
  • 9 POSTS
Usually there would be a pulley not turning. Check your alternator because that is usually the first thing to lock up. If not the alternator, check the belt tensioner. One of the pulleys has to be frozen up.
GRANDPADAVID
Engine Mechanical problem
1993 Pontiac Grand Am 4 cyl Automatic
I am trying to replace the power steering drive belt. I have located the adjustment bolt, but can't find the pivot bolt.
Can you help?
HMAC300
  • 48,601 POSTS
go to the belt routing diagram on the site here and pick out which is your engine routing. It appears to be all tensioners so the most you will need is either a 3/8 or 1/2 inch drive to move the tensioner or a there will be a bolt plainly visible to move it.
GRANDPADAVID
The power steering pump has it's own belt and is located at the opposite end of the engine from the serpentine belt. It's tensioner is a bolt which tightens the pump against the pully before cinching down the mount.
HMAC300
  • 48,601 POSTS
I've looked through several belt routing diagrams adn can't find anything like you state. I've gon through 19992-95. if it has a tensioner it might just grab the tensioner with a wwrench and see if it will move one way or another so you can get the belt off/on. Otherwise you may not have the correct info and we are looking at the wrong thing... even the manual that i have access too doesn't show anything at all on belts......
RIKKISHAE
When I start my car the fan belt squeals for a few seconds then is replaced by something that sounds like a Dremel being used to grind or cut hard stone or something metal. It is coming from somewhere near the motor mount that connects to the alternater. It continues as long as the car is in any of the forward drive gears (stops in neutral and reverse) but sometimes, when I go over a speed bump, a rough driveway or a stretch of road with a lot of jarring potholes, it will stop briefly only to return even louder. (It's really embarrassing...:) ). Any ideas
Inspect the drive belts for looseness and also could be a driven components such as the alternator, compressor, power steering pump or water pump that's making that dremel noise
JOE SWARTOUT
how hard is it to chage a belt and do you have a diagram showing pattern of belt
MMPRINCE4000
  • 8,548 POSTS
2.2 engine:
https://images.2carpros.com/forum/automotive_pictures/108325_belt_22_1.jpg
CHUCKLESOYEA
I am trying to replace the serpentine belt on my 92 pontiac grand am and I am having trouble figuring out how to release the tension on the belt I've been looking around cant seem to find anything specific I have an Idler but no tensioner is the idler the tensioner or is there something I'm missing all together
JDL
  • 16,098 POSTS
The belt routing is for a 3.1L ENGINE. Do you see the square cut-out in the tensioner, you use a rachet drive or breakover, the same size as the cut-out, pull ccw.
CHUCKLESOYEA
That does not look like my belt or tensioner the diagram on the car says only idler no tensioner the power steering is on the top left (from same vantage point as this picture) then slightly below and to the right is the idler with an arrow pointing up and right in between the P/S and Alternator the idler is perfectly round with one nut in the middle ill post a picture of my diagram it may be a bit small but you should get a better idea of whats going on
JDL
  • 16,098 POSTS
OK, what's the liter size of engine? The picture I gave is what our database showed. The databases are not always correct. I'll keep looking.
If no tensioner, then some of the accessories that run off the belt, have an adjustment slot, you loosen the nut or bolt and move the accessory to get slack in the belt.
JDL
  • 16,098 POSTS
I found this for the 3.3L engine.
CHITOWNSOUNDS
OK... I am the one doing the work Chuckles car... We finally broke down and rented a TOOL for it... the leverage of the long tool worked to loosen the tension... but NOW that we can get the belt OFF... there are engine mounts in the way of getting the OLD belt off and the NEW belt on... is there a preferred method to THAT? I see two bolts holding the engine in place from the top on some sort of rubber bushing, and it looks like that would be the ideal spot but the weight of the engine is just too much to create a big enough gap to get the belts thru. We tried jacking the engine up a lil but felt we were only lifting the car... and we tried using a giant crowbar to PRY it up (cause it looked like thats what someone had done before based on BENDS in the metal) and even THAT wasn't enough!
Jul 28, 2020 at 1:13 PM (Merged)
JALEPENO
We replaced the belt because of wear and tear. now as we drive it the serpentine belt comes off while driving.
JDL
  • 16,098 POSTS
Some makes and models, I have used a 2x4 on the lip of the oil pan, with bottle jack, take bolt out of motor mount, left the one end of engine. You need to use your own initiative about what will work and what won't. Be safe.
WRENCHTECH
  • 20,761 POSTS
It comes off because one of the components that it drives are faulty. It could be as simple as a pulley leaning slightly or a tensioner twisting from stress.
JOHNNY G.JR
  • 320 POSTS
Pulley alignment is off, possibly wrong belt installed.
  • 54,354 POSTS
Sometimes the tensioner will break internally allowing the belt to slip off. Look at the alignment and get back to us,
here is a guide that will help show you what you are in for.
https://www.2carpros.com/articles/serpentine-belt-tensioner-replacement
Please let us know what you find so it will help others.
Best, Ken
JARED575
  • 10 POSTS
Looking at my engine I have two belts, the one large belt connecting the Waterpump and Power Steering pumps and the smaller belt connecting from the waterpump to the alternator. Both belts squeal starting from the large belt that then stops transfering over smaller serpentine belt. The belts are new and I think they've just stretched a bit(under 9 months old) I've checked with a straight ruler and everything is aligned nicely. I've figured out how to tighten the alternators belt but the large waterpump/power steering belt I can't figure out. From examining the setup it looks as if the Powersteering pump needs to be adjusted to make the belt tight. I found one bolt that was loose that appears to be where it's tightened to hold it in the new position but I can't make the pump move in any direction. Is their another bolt that needs to be loosened? Their is one bolt almost opposite the adjusting bolt but it's hidden behind the pulley and I can't see how it would be used to tighten the pump as the belt and pulley would need to be removed to gain access there isn't even holes through the pulley to access it. A picture would be great. The car is a 1991 pontiac grand am LE 2.5L
HMAC300
  • 48,601 POSTS
i'll send a belt diagram along one shows the routing,which only shows one beltand the other shows the belt wear indicators on teh tensioner. that is what adjusts the belts.
HMAC300
  • 48,601 POSTS
oops hit the wrongbutton here they are
JARED575
  • 10 POSTS
Thanks, However, not sure why this is he official picture. My car is like it says 1991 pontiac grand am 2.5l LE however it uses 3 seperate belts and has no tensioner pulley. One large belt wraps around the crankshaft and travels up to the power steering and then over to the water pump. A second belt attaches also to the crankshaft and travels over to the A/C. A third belt attaches also to the waterpump and travels up to the alternator. None of the 3 belts have tensioner pulley. All the belts are adjusted by moving the A.C pump, the power steering pump and the alternator pumps to make their respective belts tighter/looser. However I am unable to make any of the respective devices move. I must be not seeing a bolt or something.
HMAC300
  • 48,601 POSTS
are you sure this isn't a 1981 grand am? everything that we have listed is serpentine drive. Of course the manual could be screwed up as well. If i saw it i could fix it as i'd know where to look.I've looked aback as far as 1985 and can't find 3 belts. sorry
JARED575
  • 10 POSTS
Absolutly positive it's a 1991. Manual must be messed becasue even Lordco gave me the correct belts for the car.
HMAC300
  • 48,601 POSTS
i can't find anything to send toyou we used to have stuff that went to1981 but since the site has a new format we no longer have that. Sorry.
