Firing order
SADIBLU22
  • 1994 PONTIAC FIREBIRD
  • 6 CYL
  • FWD
  • 100,910 MILES
Please help! I need the firing order/sequence for 1994 pontiac firebird. Six cylinder. I'm trying to fix my son's car and need help. Thanks susan
Wednesday, April 27th, 2011 AT 8:16 PM
DOCFIXIT
  • 18,828 POSTS
Here is the engine spark plug firing order. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Wednesday, April 27th, 2011 AT 8:22 PM
SASHALYNN
  • V8
  • 10,000 MILES
I need the firing order that's on the distributer for a 350 LT1 5.7 liter a 1994 model. My husband has changed the plug's and wire's and now the car will not run on all cylinder's, and so now he think's it may be the distributer.
Please help?
Monday, January 18th, 2021 AT 11:37 AM (Merged)
SLIMMILS82
Firing order is 1-8-4-3-6-5-7-2
You should have opti spark distributor so if you are hooking up the plugs on the passengers side from top to bottom will be 4-6-8-2 and the drivers side from top to bottom 5-3-7-1. Hope this is what you need.
MARTY2194
  • 1989 PONTIAC FIREBIRD
  • 120,000 MILES
Please indicate passenger side or drivers, and engine side for plugs exp drivers side.
Monday, January 18th, 2021 AT 11:38 AM (Merged)
JDL
  • 16,098 POSTS
Diagram below. Odd numbered cylinders on driver side.
TRAKTER
1989 Pontiac Firebird 6 cyl Automatic 106k miles
whats the correct order to put spark plug wires to the distributer cap. Need the diagram for this.
https://www.2carpros.com/forum/automotive_pictures/12900_fo_148.jpg
ALSNCHNS
  • 1987 PONTIAC FIREBIRD
Engine Mechanical problem
1987 Pontiac Firebird V8 Two Wheel Drive Automatic
what is the firing order for a 1987 Pontiac Trans Am/ Firebird with a 5.0 liter
  • 31,937 POSTS
Hi there,
Firing order as per pic.
Mark (mhpautos)
https://www.2carpros.com/forum/automotive_pictures/61395_Graphic_12.jpg
JRYMANWES
  • 1971 PONTIAC FIREBIRD
  • V8
What, s the fireing order for a 1971 pontiac 400cu
HMAC300
  • 48,601 POSTS
The firing order for that is 1-8-4-3-6-5-7-2 it starts at about 5-6 O'clock on the dist cap. Or if the distributor hasn't been taken out of the engine, bring it up to #1 and see where it is on the cap. It goes clockwise.
