Please let us know happens so it will help others.
Best, Ken
Feb 18, 2017 at 5:02 PM
KRISMERK913
MEMBER
1 POST
Where is the fuel filter on a 2000 Pontiac Bonneville located at?
Jun 1, 2019 at 4:44 PM
(Merged)
BLUELIGHTNIN6
CAR REPAIR CONTRIBUTOR
Under vehicle, driver side, below seating area, front of fuel tank, mounted on chassis in fuel line
(Merged)
KPAX
MEMBER
1 POST
where is the fuel filter located on a 98 Bonneville, and do I need to shut off the fuel pressure fuse, and if so, where is it located?
(Merged)
BLACKOP555
it would be good to drain the fuel pressure before, you can start the car then pull the fuel pump fuse.
the fuel filter should be about midway from tank to the engine, follow the fuel llines.
(Merged)
SUSMAN28888
MEMBER
HI,
were is the fuel filter located on a 2000 bonneville.. ponitac, 69 k..
thanks in advance,
joe
PS; if my car has one, how hard is it to replace?
Jun 1, 2019 at 4:45 PM
(Merged)
SERVICE WRITER
Yes it does. I would change it every 30-35,000 miles.
There is a plastic disconnect at one side. and threads at the other. I'm not sure how much of a pita is without a lift, but you'll need a little room to work.
(Merged)
GBELLAND
MEMBER
1 POST
I cannot find the fuel filter on my pontiac bonneville ssei, 2002, with supercharger. I am trying to replace the old one.
(Merged)
MFERK77
MEMBER
It may be right directly behind the gas tank. most vehicles have them there.if not look all around the tank.
(Merged)
LVDANGEL4
MEMBER
I know on my Bonneville it is on the passenger side in front of the rear tire. Good luck!
(Merged)
