fuel pump relay location?
1999 PONTIAC BONNEVILLE
STANDTARD
is it hard to change this fuel pump do i need to remove exhaust what would a typical quote from an auto shop be? I need to know where the fuel pump relay is as well?
Feb 12, 2010 at 1:06 PM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
Here is a guide to help test he relay with the relay location in the diagrams below.
Feb 12, 2010 at 2:38 PM
RED64
6 cyl Front Wheel Drive 100500 miles
I need to know where the fuel pump relay is located?
Jul 13, 2020 at 5:57 PM (Merged)
WRENCHTECH
  • 20,761 POSTS
Here is a guide to help you test the fuel pump relay and the location (below)
Cheers
FASTPCMAN
there are 4 relays in my 1999 pontiac bonneville under the hood. which one is my fuel pump relay ?
SUSMAN28888
  • 62 POSTS
It is relay "N" it is powered by fuse 6... They are located in the R/H instrument panel fuse/relay block
See the guide below on relay testing to help troubleshoot the problem
The fuse/relay block diagrams are attached below,
let us know if you need anything else
TWURP75
how do you tell if it is bad. i pulled the fuse out for it but can not tell if its bad
Jul 13, 2020 at 5:58 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
follow this link to learn how to test a relay https://www.2carpros.com/how_to/how_do_i_check_a_relay.htm
BENJAMIN26
I am wondering where the fuel pump relay is located on a 1997 Pontiac Bonneville? Can someone please let me know? Thank you
Jul 13, 2020 at 5:59 PM (Merged)
JDL
  • 16,098 POSTS
My info says right i/p power distribution center. I came across this in your owners manual.
https://images.2carpros.com/forum/automotive_pictures/170934_relay_center_1.jpg
HEATHER7322
Other Category problem Engine Size unknown Front Wheel Drive Automatic 100000 miles
Where is the fuel pump relay located on a 96 bonneville
Its behind the right side of dash, on dash fuse panel.
Here is a guide to help you test it
Cheers
Inbox :: Message
To: rasmataz
Posted: Thu Dec 13, 2007 11:06 am
Subject: thank you
I have a chiltons and it didn't show me where it was located I really appreciate your help. Is it hard to find once I take down the dash?
I don't think you need to go that far-just look underneath that side.
My question is what's the problem might not be it.
HEATHER7322
I just replaced the fuel pump syphon anf filter and it's not getting any juice to it and my car won't start tested it and the wiring is fine but the pump won't kick on
The relay comes On only for 2secs-get a helper for the key and recheck the gray wire for battery voltage. See below
https://images.2carpros.com/forum/automotive_pictures/12900_oil_sending_unit_and_fuel_pump_circuit_24.gif
HEATHER7322
I am not a certified mechanic so I'm not sure what the key is exactly maybe you could be more specific
MELARONJAKE
I have engine light on, loss of power up hill hesitation and shuttering while driving, idles fine, good temp n oil pressure is it the fuel pump relay? my fuel pump comes on when ignition is on, Also this problem has occured in the past but not as bad engine light didnt stay on and seemed to go away. I do have the slightest leak in intake manifold gasket but water doesnt even make it to ground and idles great. Hasnt stalled on me, If vehicle is not allowed to warm up going in reverse out of driveway gives loss of power. The loss of power shuttering n engine light happened at end of 200 mile journey ran the tank low filled up drove about 90 miles.
I mean have a helper to turn key to On while you are down there at the fuel pump connector checking for power all you got is 2secs. on that power then it disappear. Do you understand? if not come on back
SATURNTECH9
  • 30,869 POSTS
We need to start with what codes do you have?If it was the fuel pump relay the engine wouldnt run.
HEATHER7322
that helps out alot thank you so much and I will be back if I have anymore questions thank you again
HAPPYFEET12
I am wondering I got two fuel lines that broke,and a nother line that o'reighles auto parts says it go to a canister,I can't find that.plus when hooking the lines up how do you know that they are right
HAPPYFEET12
Can I get a answer please
  • 54,354 POSTS
Please post your question here:
Cheers, Ken
