2CarPros - Car Questions & Answers
1995 Plymouth Acclaim Repair Question
Topics covered: Starter, Click, Ignition switch.
Asked on April 12, 2010
1995 Plymouth Acclaim will not start
Electrical problem
1995 Plymouth Acclaim 6 cyl Front Wheel Drive Automatic 150000 miles
no power is getting to starter
Avatar Asked by hilbertdbp
Answer
Replied on April 12, 2010
Can you provide some symptoms? If you're hearing one kind of loud clunk when you turn the ignition switch to "crank", suspect worn solenoid contacts. If there's no clunk, and you don't hear the starter relay click, suspect a defective neutral safety switch. You might need to measure voltages at the starter relay socket. That will split the circuit into four parts.
caradiodoc
Tiny Answered by caradiodoc (expert)
17,336 answers provided
