Mechanics
P2004 ON MY 2.3L
2003 Ford Focus • 2.3L • 260,000 miles
Went to the dealership, was told that it was the imrc actuator, I took apart what I believed is the vac actuator, I wanted to know if this is the correct piece. I also wanted to know if there is a small test I can preform on the actuator while it's out the car to see if it is indeed the correct piece.
More information: I have two imrc solenoid on top of the intake. And followed the one of the right to get the the actuator that I pulled out. I assumed that this is the bank 1, the bank that is giving me the code p2004. Did I pull out the right one for bank 1 or is it the other "actuator" that is connected to the solenoid on the right side that is giving me the cel. I'll include pictures.
If I was indeed right the whole time can someone direct me to where I can buy a new actuator.
Taytheking
March 1, 2014.
Here is what I think is the actuator.
Taytheking
Mar 1, 2014.
The two solenoids on the top of intake, the one of the right was connected to the piece it took out
Taytheking
Mar 1, 2014.
Alil hard to see but that's the spot where I took the piece from you can see the vac line there. What looks like the other solenoid is connected too is that grayish piece in the middle (the second actuator?)
Taytheking
Mar 1, 2014.
Why are you so confident that component is the cause of the code? There are 22 pages of tests to resolve that code.
Wrenchtech
Mar 1, 2014.
The mechanic told me it was under the throttle body, on the right side of the intake, which vac lines in it. So that's where I looked and found. I also followed the right solenoid to get to that piece. So I'm like 80% sure. That's why I'm here. For the other 20%.
AD
Taytheking
Mar 1, 2014.
The mechanics, told me it was actuator. As they checked out my car for the day.
Taytheking
Mar 1, 2014.
You can't assume that is the problem. There are a dozen other reasons that code could set.
Wrenchtech
Mar 1, 2014.
The mechanics told me it was the actuator and they had a hard time looking for the part so they let me have my car back till they can find and buy the part somewhere. So I now have the opportunity to fix the problem myself after getting the free check up. Can you answer my question please.
Taytheking
Mar 1, 2014.
Being that it's an inline 4 cylinder car, I have nothing to identify bank 1 from bank 2 since it only has one bank. You can test the actuators with a hand vacuum pump to determine if they are working properly. As far as purchasing one, the dealer is the one and only place that I believe sells this.
Wrenchtech
Mar 1, 2014.
AD
