2CarPros - Car Questions & Answers
1998 Oldsmobile Intrigue Repair Question
Topics covered: Sensor, Spark, Coil pack.
Asked on June 11, 2010
Hesitation and stalling
Engine Performance problem
1998 Oldsmobile Intrigue 6 cyl Front Wheel Drive Automatic 110000 miles
My 1998 olds intrigue has a hesitation and stalls. It all started 5 days ago and I have not driven it more that a few miles since. It starts to hesitate anytime after about 1 mile of driving. It has stalled on me four time time, all after the car has warmed up. The first three were within about 1/2 mile. Also, when looking over the engine after the stalls, with no on in the car, it reved up then wanted to die. It does this several times then idles smoothly for a minute or so the repets. We change the spark plugs and are concidering changing the coil packs. Do you have any suggestions we can look at first?
Thanks ...
Rick ....
Avatar Asked by tigerbuck57
Answer
Replied on June 11, 2010
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Tiny Answered by rasmataz
68 questions asked
