where is the fuse box at?
1996 OLDSMOBILE CIERA
ERIC32
Headlights tail lamps wont work where is the fuse box at?
Dec 16, 2011 at 2:38 AM
  • CAR REPAIR CONTRIBUTOR
Here is guide that will help you test the fuses and the fuse panel diagrams below.
Dec 16, 2011 at 2:45 AM
DRCRANKNWRENCH
  • 3,380 POSTS
There is a 20 Amp fuse that the headlights and tailights share, check that. There should be a diagram of the fuse box on the backside of the fuse box cover. It also has short desriptions of what the fuse is for. The diagram can be hard to orient to the fuse box sometimes so use the spare fuses and/or the large relays to orient yourself with the diagram.
Dec 16, 2011 at 2:55 AM
ANTHONYBARLOW
Electrical problem
1994 Oldsmobile Ciera
there are at least two fuses missing and when i check the fuses with the lightmeter (not sure what its called) It only lights up on a couple of fuses, and then test again and not at all. windshield wipers fuses etc(wipers work)but wont light up. I know there are at least two fuses missing but Im not sure what fuse to use. dont have a owners m anual and ive looked all over net. Please help. P.s. original problem was my wife took car to work and then she went to leave it would not start. electrical worked but zero turnover, towed it home and two days later it turned right over. thanks for your time. Anthony
Feb 23, 2019 at 3:23 PM (Merged)
https://images.2carpros.com/forum/automotive_pictures/12900_f_9.jpg
No crank at all/nothing/nada when key is engage to starting position Could be the starter, starter relay, clutch switch/park and neutral switch/transmission position switch and ignition switch assuming the battery and connections are good. Note:If it doesn't apply disregard.
MOMRN
How many and where are the fuse box (s) in this car?
JDL
  • 16,098 POSTS
Welcome to the forum, look behind right side of dash to left of glove box.
