Heat Blend Door Actuator
2003 OLDSMOBILE ALERO
104,000 MILES • 4 CYL • FWD • MANUAL
EDELL
The heat does not come on when I change the temperture controll to warm. It is vacume and I do not hear any noise when i turn the controll. However I cannot find anywhere either in my owner manual, repair manual nor so far on the internet at to where this actuator is, or how to change it.
Thank you for your assistance.
Sep 10, 2014 at 12:09 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
The actuator will be on the HVAC system under the dash on the passenger side. It is attached to the heater core box.
Here's a guide on changing the actuator, not your exact car but it is very similar
See the diagrams below for replacing it
Sep 10, 2014 at 5:29 PM
EDELL
Thanks for your help. Found it and got it out and fixed.
Sep 12, 2014 at 9:03 AM
  • 110,190 POSTS
Glad you got it fixed.
Sep 12, 2014 at 6:56 PM
2CP-ARCHIVES
  • 4,540 POSTS
How do I get to the blend door actuator on this car?
Feb 7, 2019 at 7:05 PM (Merged)
  • 54,350 POSTS
Here is a guide that will help show you what you are in for by going this repair:
REMOVAL PROCEDURE
Remove the instrument panel compartment.
Disconnect the temperature actuator electrical connector.
Remove the two screws from the actuator.
Remove the actuator.
INSTALLATION PROCEDURE
Install the actuator
NOTE: Refer to Fastener Notice in Service Precautions.
Install the actuator screws.
Tighten
Tighten the screws to 2 N.M (18 lb in ).
Connect the temperature actuator electrical connector.
Install the instrument panel compartment.
Here are some diagrams for your car.
Please let us know happens so it will help others.
Best, Ken
BOBSHAWESCAPE
My girlfriends Alero heater controls allow only the high speed on heater/ac control and the heat/ac only comes through the vents (not defrost, floor, mix, etc.). From what I've read on the net the blower speed problems can be resolved with a new blower resistor. Fine I can handle that but anybody have some ideas on the lack of vent, defrost, floor controls?
Any help is much appreciated,
Bob
ps
its a wisconsin winter so i need any help to make this work
IMPALASS
  • 3,112 POSTS
Hello The doors are control by a vacuum hose that is coming off of the intake manifold. I can't seem to locate that hose so you are going to have to search around. Since all the doors do not work, my guess is that one main vacuum is either not working or disconnected. I have attached the vacuum diagram for the doors as you see to the left..they all work off of the one main vacuum..that would be my guess. I have also attached the location for the relay and the resistor.
https://images.2carpros.com/forum/automotive_pictures/248015_104277980_1.gif
https://images.2carpros.com/forum/automotive_pictures/248015_105626450_1.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_Picture1_25.jpg
BOBSHAWESCAPE
The vacuum hose im looking for is typically a small rubber hose? and coming right off the intake manifold? Sorry to ask but I can't read the writing in the pictures and when i try to blow them up they lose resolution
Thanks in advance,
Bob
JAMES W.
  • 2,394 POSTS
The vacuum hoses for the damper control are usually bright colored plastic. ie red, blue, black, etc. If you can't find a tube like this on the manifold, you may have to get to the back of the selector switch in the dash. Most common problem is loss of vacuum at the manifold or a bad selector control.
I'm in Minnesota, and heat is kinda' important up here. Hope this helps.
IMPALASS
  • 3,112 POSTS
Bob Sorry for the delay. I was experiencing some minor technical difficulties Thanks Mr Weizel for assisting. I have attached some more pics for better viewing. The one with the red circle shows that the vacuum comes in from the engine and connects to the HVAC Control Assembly Valve. As you make the selections the vacuum should be present but changes direction and causes the doors to move. I have attached 4 more pics of the same thing blown up in 4 sections that overlap. Hope this helps. Let us know if not. Also please follow the advice of Mr Weizel. Most common problem is loss of vacuum at the manifold or a bad selector control
https://images.2carpros.com/forum/automotive_pictures/248015_Picture5_11.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_1_101.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_2_66.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_3_49.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_4_29.jpg
IMPALASS
  • 3,112 POSTS
Hello One last thing You may have some recalls on your vehicle. The dealer may fix these for free. Please contact the dealer service department, give them the VIN number of your car and have them check on these to see if they apply to you.
https://images.2carpros.com/forum/automotive_pictures/248015_Picture7_11.jpg
