Air Conditioning does not work
2001 NISSAN XTERRA
87,000 MILES • 6 CYL • FWD • AUTOMATIC
HOCSINH
  • 5 POSTS
I have my car AC service for like 6 months ago. My AC always blows out cold air whether or not i turn on my AC. but now i did not get the cool/cold air, but only warm air when AC is on or off
Any advice appreciated.
May 27, 2008 at 12:25 PM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
Hi hocsinh,
Without AC on how to get cool air? I am a confused.
Check for compressor operations with AC on.
Check positioning of venting system.
Check heater control cable adjustment. This guide will help
Jun 9, 2008 at 11:11 AM
HOCSINH
  • 5 POSTS
the AC is on
the compressor is running when i checked
the air is warm whether or not the vent is on or off
i can hear some kind of noise from the passenger's side. is that meant there is a leak?
what else should i check?
thanks,
Jun 12, 2008 at 4:30 PM
KHLOW2008
  • 41,814 POSTS
Hi hocsinh,
If there is noise from the passenger side, could be the expansion valve.
Get a pressure test on the system and let us know the readings.
Jun 13, 2008 at 8:20 AM
HOCSINH
  • 5 POSTS
Thanks a lot for your replies, KHLow2008
Finally, i brought my car to the auto shop dealer for the AC check and there is a leak from the high pressure pipe/tube as they told me
how easy and how much it costs to replace the pipe/tube estimately?
thanks,
Jun 14, 2008 at 1:02 PM
HOCSINH
  • 5 POSTS
Another mechanic checked and told me the leak is coming from the AC evaporator and it would cost $690 to fix it.
I am not sure who is to believe?
any suggestion?
thanks!
Jun 14, 2008 at 2:26 PM
KHLOW2008
  • 41,814 POSTS
Hi hocsinh,
Sorry I can't help you about the price. but the pipe repair should cost less.
Since 2 person have told you 2 different possibilities, you might need a 3rd opinion.
Jun 14, 2008 at 3:47 PM
HOCSINH
  • 5 POSTS
thank you, KHLow2008
Jun 14, 2008 at 4:29 PM
DANNY BLACKBURN
  • 11 POSTS
Replace the high pressure line yourself. Buy a new line or go to junk yard and get one and charge the system up before spending lots of money.
Jun 6, 2019 at 7:24 AM
ROSEMEADE908
My air conditioning just stopped working, when I press the AC nothing happens, before I could immediately hear the compressor turn on. I could not find a fuse in the under dash fuse box, is there another fuse box? Is the AC not working?
Sep 16, 2019 at 9:47 AM (Merged)
DOCFIXIT
  • 18,828 POSTS
Check the engine compartment also is the system fully charged?
This guide should help
ROSEMEADE908
Engine compartment, is where another fuse box would be located?
Also even if the system needed charging would the compressor still turn on but just blow warm air?
DOCFIXIT
  • 18,828 POSTS
Box under hood probably near batt.
System has low pressure cutout switch so comp. will not run when system is low to prevent damage to comp.
TLANE77785
Air Conditioning problem
2001 Nissan Xterra Automatic
My air conditioning smells like an odor!! where is it located on the car so I can get the filter cleaned. It smells like body odor!! I really need to change this out this smell makes me want to vomit.
DOCFIXIT
  • 18,828 POSTS
Your vehicle does not have a filter. Most likely mold in evaporator or a little critter got in intake vent. see diagram take motor out spray Febreeze and water bleach solution.
ALX2979
Hello I have my xterra, my ac is not working I just put 134a+ refrigerant just install new thermal control amplifier new pressure switch my ac light in my dash comes on compressor is good can you guys help me please thank you
Could be still low in freon-Do you hear the clutch engage the compressor
ALX2979
This is what I did In fuse box I found the compressor fuse I brige from the batery + to the wire the goes to the compressor Works and I can get cool air but when I put the fuse back stops working like I say the ligh in the dash it's on the pipes on gets cool and the other one gets hot it's that normal? I change the bottom in the dash to any idea
Check and test the AC clutch relay and the pressue switch
ALX2979
The a/c clutch relay it's new and the presure swich is new and I getting power
DANNY BLACKBURN
  • 11 POSTS
I have a 2000 Xterra and air just quit working. Compressor wouldn't come on and light was coming on. The 4 wire plug on top of bottle on pass side, I pulled it out and put back in an tried to get plug out on top of compressor but couldnt get it come out. I tried it again and it started working. Check all your plugs, one of them might not be getting connection.
RALPH99ZRZ
I have a 2000 Nissan Xterra, 2WD, V6 with about 89,000 miles. The air conditioner works about half of the time. When it works, it is ice cold. When it doesn't, it blows warm air. So I know it is not a freon leak. It is pretty much random when it works and when it doesn't, although I believe it works more often when moving then when stopped. However, it will often go warm when driving, and it will sometimes blow ice cold when stopped. It doesn't matter whether it is really hot or cool outside. Toggling the a/c switch doesn't really help either. Turning the A/c off, waiting a few minutes, and turning it back on works sometimes, and sometimes not. Basically, it is pretty random when it does and does not work. Any ideas what the problem might be? Thank you.
RALPH99ZRZ
In addition to the facts I described, I forgot to mention that often times the a/c will work for like 10 minutes straight, then stop for a few minutes, and then start working again, without touching the a/c button or fan selection switch. And vice versa--sometimes I will turn it on and it won't work, and then all of a sudden cold air starts coming out without touching anything. I figured that might rule out the switch being the problem.
DANNY BLACKBURN
  • 11 POSTS
If you ran a hit wire to fuse and it worked, then it sounds like the hot wire on fuse is not hot.
2CARPRO JACK
  • 11,533 POSTS
If the freon pressures are good then it could be a pressure switch that is going bad.Really needs to be looked at when the A/C isnt working to see what is going on.Many different things are possible.
  • 54,352 POSTS
If you move the wire at the compressor it could be the clutch coil is bad FYI. Here is a guide that can help find out what is wrong with the system.
Let me know if you need any help.
DANNY BLACKBURN
  • 11 POSTS
Mine is fixed but thanks
  • 54,352 POSTS
What was wrong?
DANNY BLACKBURN
  • 11 POSTS
I pulled four wire plug out on top of bottle and tried to unplug the plug at compressor and couldn't get it out, so I put four wire plug back in and cranked it and turned on A/C and it was working good and still is.
CHARLES OWENS
2000 Nissan Xterra 6 cyl Two Wheel Drive Automatic
The A/C cools good when the outside air is cool and when the engine is run for the first time. After it has been shut off, the A/C doesn't cool during hot weather. I checked the low side pressure with one of those R-134 cans with the gauge and it's running at 60psi at idling speed. The pressure goes down to about 40psi with increased RPM's. Sometimes after driving for a long period, the air might begin to cool off. That's about it. Please help.
KHLOW2008
  • 41,814 POSTS
Hi Charles Owens,
It could be expansion valve, excessive refrigerant or compressor.
Check high pressure for abnormality.
  • 54,352 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
