engine wiring diagram
1995 NISSAN SENTRA
ANONYMOUS
wiring problem, where the signal to the brain that need wiring diagram fuel supply to the engine for can find the wiring diagram for the car? I will be very grateful.
Aug 24, 2013 at 11:22 AM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
Here are the engine wiring diagrams and a guide to help you test the connections
Aug 25, 2013 at 1:26 AM
ALIENSATEMYCAT
The car cranks but will not start. Want to test MAF wiring, but can't find wiring diagram online. Three wires, one red, one green, one red & white. Which one is hot, and which is ground. What is the other? I've had this problem before. It wouldn't start at home so had it towed to shop, but would start at shop so they couldn't diagnose MAF problem at those times. We tuned up, so new plugs, and plug wires. It's getting fuel and spark, so we're looking at the mass air flow sensor as the possible problem. What else could it be?
Feb 21, 2019 at 11:48 AM (Merged)
STEVEW84
  • 673 POSTS
What is your fuel pressure at? Are you getting an inj. pulse? Do you have compression? Do you have any codes?
