2CarPros - Car Questions & Answers
1988 Nissan Pathfinder Repair Question
Topics covered: Spark, Gas, Compression.
Asked on November 13, 2009
1988 Nissan Pathfinder won't stay running
Engine Performance problem
1988 Nissan Pathfinder 6 cyl Four Wheel Drive Manual 107000 miles
i had to pull home a car yesterday. after i got it home i went to run an errand and the pathfinder just shut off.i was able to start it a couple of times it seemed week and i could smell a sulfur smell. had it pulled home. started last night but i shut it down. started it today but died when i applied gas and won't restart. help you don't think towing a car did this do you
Avatar Asked by project37
Answer
Replied on November 18, 2009
Hi project37,
Thank you for the donation.
I don't believe towing another vehicle did this.
You would have to start from the basics to understand what is wrng. Here is a link for you to check out what is missing causing the non starting. Let me know if you have additional information.
http://www.2carpros.com/kpages/first_things.htm
Follow the link that aptly describes the condition.
Tiny Answered by KHLow2008 (expert)
39,832 answers provided
Replied on November 21, 2009
i know that it is getting plenty of gas to the throttle body and there is spark to the plugs what is left. i forgot to mention. the shows this to be an idle up solenoid it seems to be wet sometimes
Tiny Response from project37
4 questions asked
If you have sparks and fuel, the next item to check would be the compression pressure.
Replied on November 24, 2009
we advanced the timing through the distributor all the way for it to start.while it was running it ran ruff and if you gave it gas it would die. it did start and run for several minutes before it died. while it was running the tach was jumpy before it quit and their was some water and rust coming out of the tail pipe. of course it hasn't been started in over a week.
4 questions asked
Water out of tail pipe after sitting for extended periods are normal as condensation in the exhaust system would be purged out but you need to check the coolant level to see if it is correct. Hope you have not damaged the head gaskets due to overheating.
did you test the engine compression?
A jumpy tachometer is an indication the ignition coil is faulty and that could be the reason you are not able to start. Sparks might be present but are they strong enough? Are the sparks bright blue or dull orange?
the coolent level is fine. it hasn't over heated. havn't ran the compression test yet. tested for spark with a in line spark tester. when we took out the #1 plug it looks like the plug they show on this site where they say it is carboned over but dry. these plugs have been in the truck less than a year. i guesse it was orange when he tested the plugs
4 questions asked
Replied on November 25, 2009
Orange colored sparks means the ignition coil is weak and that can cause non starting. Get the coil checked.
i will thanks
4 questions asked
Replied on November 27, 2009
we replaced the coil and the spark is still orange
4 questions asked
Replied on November 28, 2009
Is it an OEM coil ? Brand new?
Is the tachometer still jumping around?
