1998 Nissan Other Repair Question
Topics covered: Engine, Sensor, Air filter.
Asked on August 8, 2008
1998 Other Nissan Models EGR causing misfire in Cylinder 1?
I have a 98 nissan 200sx se-r. I recently replaced all the spark plugs, wires, distributor cap, rotor, fuel filter and air filter. One problem I'm getting is once in awhile I get a engine code: knock sensor and misfire in cylinder 1. It doesn't always come on. Well when I'm driving at cruising speed the engine hesitates and stumbles. Even at the a dead stop the engine jerks for a few seconds. When I stomp on the gas it runs fine just cruising is when it happens. I did a compression test: 175/175/165/175.
I have 3 things in mind that it could be but i'm not sure: tps sensor, o2 sensor or the egr valve. What can be the problem?
