Mechanics
AIR CONDITIONING DOES NOT KICK IN AT LOW
1997 Nissan Maxima
Air Conditioning problem
1997 Nissan Maxima 6 cyl Two Wheel Drive Automatic 161000 miles
My air conditioning only seems to work when travelling at freeway speeds. No matter how long I drive in the city, it does not cool down the car. To try to solve the problem a year ago, I had the air conditioner serviced at the dealer, which I think involved cleaning it and charging the freon. They did not find anything else wrong with it.
Is there some specific problem that would cause the ac only to work when travelling at freeway speeds.
Thanks
Isaac17
May 29, 2008.
Hi isaac17,
Check with AC on and engine idling,
1. Compressor clutch is engaged?
2. Cooling fans working?
Are the condersor or air flow restricted?
If the compressor operates at low rpm but the cooling is inefficient, you need to check the pressure. A weak compressor would cause the problem.
AD
KHLow2008
Jun 1, 2008.
I had the same exact issue the dealer replaced some soilnold behind the control on the dash and now fixed cost me 199.00
97BLKMAXIMA
Jun 9, 2008.
AD
