Fuel pressure specs
PRISCIV627
  • 1995 NISSAN MAXIMA
What is the fuel pressure on a 1995 nissan maxima se 3.0 liter engine?
Thursday, January 26th, 2012 AT 6:27 PM
DOCFIXIT
  • 18,828 POSTS
The fuel pressure should be 34 psi vacuum to regulator here is a guide that will help you test the fuel pressure.
Thursday, January 26th, 2012 AT 6:50 PM
MAXIMA_1993_OWNER
  • 1993 NISSAN MAXIMA
  • 6 CYL
  • FWD
  • MANUAL
  • 170,000 MILES
After a 2 year sit, I decided to get my 1993 Maxima running again. I had less that 1/4 tank when I parked it but forgot to add any stabilizers. So it would run but very badly with additives and I took it to our local mechanic (NAPA auto repair). They found that the gas tank had a lot of sediment and sludge in it so they replaced it. They said the fuel pump worked great (it's only 3 years old) and I drove it home just fine with a fresh tank of gas. At around the the 900 mile mark from the repair, I started having the car cut out and stutter while driving. I've found that I can shut the car off and it's fine once i've let it sit for a bout 30sec-1min, but it starts acting up again after a few minutes. This gets worse the lower the gas tank gets. If I top it off, it runs fine until I hit 3/4 tank then starts the stuttering again. I'm guessing that somehow the fuel pressure is dropping just from the weight of the gas in the tank getting lower, but how would one figure this out for sure?
Thursday, January 10th, 2019 AT 7:16 PM (Merged)
Check the fuel pressure to find out what the fuel pump is doing-could be on its way out-
DAV30
  • 1994 NISSAN MAXIMA
1994 Nissan Maxima 6 cyl Automatic
How do I check the fuel pressure? I was unable to find a check valve on the fuel rail. Thank you
Thursday, January 10th, 2019 AT 7:17 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
You have to use a "T" connector and connect the fuel gauge between the fuel filter outlet and fuel tube using the "T".
JACKSONJ
  • 1992 NISSAN MAXIMA
  • 140,000 MILES
Sometimes engine will not start. When it does, it runs fine, no stalling. I have replaced fuel filter, pump relay, and checked vacuum line to pressure regulator. Thumbnail check said to remove line from filter to regulator to see if gas was in line. None, which points to pump. I turned key on with line disconnected and in gas can, no gas came through line. The pump is only 2 years old, but aftermarket. I have no diagnostic equipment and nearing broke.
  • 108,192 POSTS
If you are not getting fuel, check to make sure the pump is getting power. IF it is, then it is bad. If there is no power, check fuel pump relay.
454TIMU
  • 1990 NISSAN MAXIMA
  • 6 CYL
  • FWD
  • 190,000 MILES
Where do I find the fuel pump, fuel pressure regulator, and the fuel pressure relay.
BLACKOP555
  • 10,371 POSTS
Fuel pump is in the fuel tank, the fuel pressure regulator is on the fuel rail.
And I will try to find a diagram for your relay, where it is located amongst the others.
