Serpentine belt diagram and help
UGAGIRL
  • 2014 NISSAN ALTIMA
  • 2.5L
  • 4 CYL
  • 123,000 MILES
I need the diagram for the car listed above's serpentine belt and any advice or how to on replacement. Thank you!
Tuesday, June 18th, 2019 AT 9:42 AM
Hi UGAGIRL,
Here is the procedure and the diagram of the belt routing. Please let me know if you need more information.
Tuesday, June 18th, 2019 AT 12:53 PM
MARINITO
  • 2010 NISSAN ALTIMA
Is the drive belt routing for 2010 nissan altima?
Thursday, September 10th, 2020 AT 12:04 PM (Merged)
There are two different engine in this car so here are both diagrams and a guide to help you change the belt out below.
https://www.2carpros.com/articles/replace-serpentine-belt
PACHYAUTO63
  • 40 POSTS
  • 2006 NISSAN ALTIMA
  • 2.5L
  • 4 CYL
  • 125,000 MILES
I need a diagram on how to put the belt on.
Thursday, September 10th, 2020 AT 12:05 PM (Merged)
WRENCHTECH
  • 20,758 POSTS
Here is how you install the serpentine belt. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
ASHLEYGS
  • 2005 NISSAN ALTIMA
Engine Mechanical problem 4 cyl Two Wheel Drive Automatic 106375 miles
I need the diagram for a 2005 Nissan Altima 2.5 S
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,288 POSTS
Here is a guide to show you what you are in for when doing the job.
https://www.2carpros.com/forum/automotive_pictures/12900_db_3.jpg
https://www.2carpros.com/diagrams/nissan/altima/2004
Check out the diagrams int he link above
Cheers, Ken
SPIROKINTA
  • 125,000 MILES
How can I get a serpentine belt routing diagram?
  • 52,797 POSTS
Below
CHAPLAIN D
  • 2002 NISSAN ALTIMA
2002 Nissan Altima 4 cyl Front Wheel Drive Automatic 96k miles
my serpertine belt is vibrating coming off the alt and making noise. When I lube it a little it stops so I m assuming that it needs changing what is the belt route and do I need to remove the top mount.
  • 31,937 POSTS
Hi there,
Belt set up as per pic,
Mark (mhpautos)
https://www.2carpros.com/forum/automotive_pictures/61395_Graphic_16.jpg
