Radio not working
2005 NISSAN ALTIMA
60,000 MILES • 6 CYL • 2WD • AUTOMATIC
EJLETO
My sons battery died and he had a friend jump start him. After doing so, his radio does not work. I think it is a fuse but I cannot be certain. Everything else works fine. I have looked in the manual for what type of fuse and its location in the car, but I cannot find it. I have looked under the driver side compartment area and see some fuses there but the panel does not list the radio there. Is there somewhere else to look in the car besides under the hood (which I will check tonight) to look for the fuse? I also will look in the glove carpetment later tonight. Would the fuse be a 10 or 15 amp? Any help you could offer would be great.
Thanks,
EJ Leto
Jun 26, 2015 at 6:58 AM
JOHNNYT73
  • CAR REPAIR CONTRIBUTOR
  • 924 POSTS
Your radio fuse should be in the interior of the vehicle not under the hood. I would recommend buying a test light and turning the key and test all the fuses (touch both terminals on top of the fuse). If a fuse only lights up on one terminal and not the other then you know that fuse is blown.
Here is a guide to show you how with the fuse locations in the diagrams below.
Jun 26, 2015 at 7:33 AM
SPURLOCKAP
Interior problem
2006 Nissan Altima 4 cyl Automatic
My car radio works but there is no sound! The screen shows the volume change when turning the dial, the time, the channel and it also reads cd's there is just not sound. What could this be?
May 3, 2019 at 1:31 PM (Merged)
734TRQ
[quote:a34e7a81e7="spurlockap"]Interior problem
My car radio works but there is no sound! The screen shows the volume change when turning the dial, the time, the channel and it also reads cd's there is just not sound. What could this be?[/quote:a34e7a81e7]
Mine did that also. After a couple weeks, it started working when the car was warm, and now works like normal at all times/temperartures. Never did solve the problem. 734trq
MICHELMAKALA
1999 Nissan Altima Two Wheel Drive Automatic
I bought my second car last Tursday.
I do not have a code to activate the audio, radio and CD sytem.
Also I do have a problem when trying to open
the outside window of the tank to put gaz.
And it was at -25 degree at a gas station.
Was it frosen.
Please help me to get the manuel of 1999 nissan
altima and th problem of Audio ,cd
Summary of problems
CD, Audio' Radio not working
Operator manual
ZACKMAN
  • 4,202 POSTS
I can be wrong, but as far as I know, 99 Altima does not have anti-theft radio, thus no code is required to turn on the radio. You may want to check these two fuses, though, fuses #10 and 35, both 10A inside the fuse block under the driver side dash.
https://images.2carpros.com/forum/automotive_pictures/55316_99altimaradio_1.jpg
As for the fuel door, you may need to spray some deicer to get the door to open. You may also open the trunk, remove the carpeting around where the fuel door is, you should see a release cable that you can pull to unlock the door, as well.
