2CarPros - Car Questions & Answers
1997 Nissan Altima Repair Question
Topics covered: Fuel filter, Hesitate, Distributor.
Asked on July 29, 2010
1997 Nissan Altima Misfiring on low acceleration
Engine Performance problem
1997 Nissan Altima 4 cyl Two Wheel Drive Manual 204000 miles
Hi, I have a big problem on my car. I bought it used about a month ago, and I can't find what the problem is. It was fine when I bought, up to like a week later. It misfire (hesitates) everytime I keep a low acceleration. If I don't accelerate or if I speed up (press the accelerator harder) it will not misfire/hesitate. Would you guys know the problem?
The only thing I found that could be the problem was a little bit of oil inside of the distributor cap, but I cleaned and even changed it, but still misfiring.
Thank you very much for your time.
Anderson
Avatar Asked by andersonribert
Answer
Replied on July 29, 2010
Could be an ignition issue.At that mileage you should be on your second major tune up (plugs/wires/cap/rotor/fuel filter). Making sure all of the basic ignition is in proper order is the best place to begin, especially for misfires like you describe.Also you should always use OEM (original equipment manufacturer) parts to keep it running right
Tiny Answered by 2CarPros Jack (expert)
12,033 answers provided
Thanks for the reply. I already changed half of this parts, I will change the fuel filter today. If it doesn't fix it, any other suggestion?
Thank you for your time.
Tiny Response from andersonribert
1 question asked
Replied on August 1, 2010
could be an injector issue, but get all of the ignition replaced first
