1985 Nissan 300ZX Repair Question
Topics covered: Sensor, Spark, Fuel filter.
Asked on June 26, 2010
1985 Nissan 300ZX stalling
Engine Performance problem
1985 Nissan 300ZX 6 cyl Two Wheel Drive Manual 195000 miles
i have cleaned the injectors, replaced fuel filter, fuel relays, distributor cap, rotor button, spark plugs+wires, starter, and established the pump is in working condition. i have adjusted the timing. the car will idle for a moment then it slowly drops in rpms and while driving it will randomly stall out and sputter when u attempt to accelarate
Answer
Replied on June 27, 2010
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking,fuel filter or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
