Car has lost power, neutral light keeps on.
DICKSON MUSAU
  • 2001 MITSUBISHI LANCER
  • 102,500 MILES
Car has lost power, neutral light keeps on flashing when on drive. It can move on a smoooth road but stalls on a slight elevation
Monday, October 22nd, 2012 AT 7:30 AM
KHLOW2008
  • 41,814 POSTS
This sounds like you have an input shaft speed sensor that has failed, here is a video of one being replaced.
https://youtu.be/f3bETtCIdxM
Here is the location for your car
Cheers
Monday, October 22nd, 2012 AT 1:25 PM
DICKSON MUSAU
Nice work that was it once I replaced the sensor and car shifts perfect with no light on :)
Sunday, October 28th, 2012 AT 1:05 PM
JOHN MAGNUMBOSS TORRENCE
Found the connection off the sensor put it back on and car is back to normal thank you very much.
Saturday, October 20th, 2018 AT 5:08 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,047 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
Monday, October 22nd, 2018 AT 10:15 AM
NAZARAHMAN
  • 4 CYL
  • 101,200 MILES
Problem with engine running with 2 cylinder. Check with scanner and found with 2 code error.1) etv 2) etc. Before engine can start but only the idle not stable at 1000rpm. Sometime engine stop
Monday, October 22nd, 2018 AT 10:16 AM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi nazarahman,
What are the trouble codes retrieved?
Which 2 cylinders are not working?
PATTIT
  • 2003 MITSUBISHI LANCER
  • 4 CYL
  • FWD
  • 11,520 MILES
The air conditioner works but the car stalls almost immediately when I turn on the air conditioner. I am guessing about the wheel drive type above by the way, I have no idea. This just started this season, previously had no problems at all. I am thinking of getting a tune up and timing belt, do you think that would help?
KHLOW2008
  • 41,814 POSTS
Hi pattit,
Thank you for the donation.
A tuneup might not help. I would suggest getting the throttle body and Idle Air Control cleaned.
REBECCAHILL
  • 190,000 MILES
I just bought my car about a month ago and it was running really well until I noticed when starting the car and going from park to reverse the revs can jump up a little, then from reverse to drive it does it again and the car almost stalls. It seems to be ok if I leave it a few seconds between gears, but it doesn't feel right. Has just had a service with an oil change and filters, cambelt is due in the next 10-20,000 ks.
KHLOW2008
  • 41,814 POSTS
Is the Malfunction Indicator Light showing and have you checked for trouble codes?
REBECCAHILL
Hi, sorry, Im not that knowledgable about cars, Im assuming you mean running a diagnostic test or something like that. No lights come on, it sort of only does it intermittently. Would you recommend taking it to somewhere that can hook it up and check for codes?
KHLOW2008
  • 41,814 POSTS
Yes, that is what I meant. Strat by getting the codes read and you can get them read free at most parts stores if you are located in the US.
Come back with the results and do not change anything first as the people doing these for you only knows how to read codes and can't really diagnose the problem for you.
In the meantime, check the transmission fluid level and condition. Good transmission fluids should not look dark or brownish.
Does the
VEDOVAAW
  • 2002 MITSUBISHI LANCER
Engine Performance problem
2002 Mitsubishi Lancer 4 cyl Two Wheel Drive Manual
My car stalls when idleling. It runs fine but when I hit a traffic light the car stalls when it idles, it seems that the rpm's lowers to less than 1000 rpm to 500 rpm
KHLOW2008
  • 41,814 POSTS
Hi vedovaaw,
Erratic idling are usually due to the Idle Solenoid Control (ISC) valve, commonly known as the Idle Air Control Valve ( IAC).
Get the IAC and throttle body cleaned and retest. Is the Check Engine Lamp indicating?
RINI
  • 2000 MITSUBISHI LANCER
  • 4 CYL
  • FWD
  • 175,000 MILES
Hi I have a 2000 Mitsubishi lancer auto vrx with 175000km and all of a sudden whenever I drive its about to stall it shakes and struggles every time I accelerate or am just sitting there at the traffic lights please help
Monday, October 22nd, 2018 AT 10:17 AM (Merged)
  • 31,937 POSTS
You may have a fuel pressure problem, or a TPI sensor acting up, best to start with a scan to check for any unresolved fault codes, this is always the best place to start a diagnosis for this type of problem.
Mark (mhpautos)
RSHAW
2002 Mitsubishi Lancer Automatic 80000 miles
My car dies sometimes when I slow down at an intersection or a stop light and put my foot on the brake. It also dies sometimes when I press the gas too hard or sometimes even at a normal pace. When I turn the ket after this as occured, there is no problem getting the car to start again. I have also noticed that sometimes when I allow the car to trottle, the front shakes and it sometimes dies (not often). When I nuetral it and floor the gas pedal the car resist as if to suggest that it might die. I have took it to several mechanic explaining the issue and they keep cleaning the trottle body area but the problem contiues to occur. I would greatly appreciate if you could tell me what is wrong with the car.
KHLOW2008
  • 41,814 POSTS
Hi rshaw,
Since the throttle body is not the source, I would suggest checking the following.
1. Valve clearances if they are not the hydraulic type.
2. The map sensor.
3. The speed sensor.
HOTTIICEE
  • 1999 MITSUBISHI LANCER
Engine Mechanical problem
1999 Mitsubishi Lancer 4 cyl Front Wheel Drive Automatic 65000k miles
My girlfriend has a mitsubishi lancer 2001 model cedia CS2 with a GDI engine and CVT transmission. The problem is that the engine usually cuts off sometimes when driving or when in traffic. Can you please advise, thanks!
TECHNOPRO
  • 45 POSTS
Usually the throttle body needs to be cleaned and the inlet as well. The bucket filter on the high pressure fuel pump has to be replaced as well. They are known to get trouble with the fuel pumps(HP) but I think the best way is to get it to a Mitsi dealer as the technicians will know what and where to look for compared to other non mitsi technicians.
There is a special product sold by MMC to slean the inlet manifold and it's called "schuma"
Let me know how you get on.
