A/C leak
2003 MITSUBISHI GALANT
199,128 MILES
RASHUN HARRIS
Freon is leaking from the top of the compressor from a tiny hole.
Jun 26, 2019 at 11:39 AM
  • CAR REPAIR CONTRIBUTOR
Good afternoon,
That is the pressure relief valve for the compressor.
You need to replace the compressor.
https://www.2carpros.com/articles/replace-air-conditioner-compressor
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Jun 26, 2019 at 12:17 PM
SMLBHPPY04
2003 Mitsubishi Galant
The carpet inside my car on the passenger side front and back has a black liquid that smells sour, and when the AC is on and I make a left turn it makes a rubbing noise. What could it be?
Jun 27, 2019 at 10:42 AM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi smlbhppy04,
This guide should help
https://www.2carpros.com/articles/air-conditioner-leak-detection
There should not be any black liquids and if what you heard is sloshing noise as if water is moving around, then most probably the black liquid is contaminated water from the evaporator. Check for clogged drain hose at the bottom of evaporator housing.
KINGBOY69
my daughters mitsu.. leaks water into passenger side floor. Its not heater core its the ice buildup from the a/c. How can we correct it?
  • 31,937 POSTS
Hi there,
you will have to check & clean the evaporator drain tube,i think on these it will be at the lower portion of the fire wall behind the A/C unit it will be a short rubber tube.
Mark (mhpautos)
