Mechanics
SERPENTINE BELT REPLACEMENT
2005 Mercedes Benz C230
Engine Mechanical problem
2005 Mercedes Benz C230 4 cyl Two Wheel Drive Automatic 115000 miles
How do I replace the serpentine belt on this vehicle?
Ojrmauricio
July 15, 2010.
Hi ojrmauricio, Welcome to 2carpros and TY for the donation
C230
http://www.2carpros.com/forum/automotive_pictures/12900_vbelt_1.jpg
ENGINE 271.956 in MODELS 211.041 /241
Fig. 13: Identifying Poly V-Belt Remove/Install Components - Engine 271.948
Removing
1Open engine hoodModel 203AR88.40-P-1000P
Model 209AR88.40-P-1000Q
Model 211AR88.40-P-1000T
2Remove wideband silencer AR09.41-P-6825T
3Loosen poly-V-belt (1) and remove Use the Torx recess below the tensioning pulley (2) for this purpose and swivel in anticlockwise direction (arrow).
Take off poly V-belt (1) and decelerate tensioning pulley (2).
Checking
4Inspect belt pulley sections and tensioning device Installation: Check the belt pulley sections and the tensioning device for any damage and dirt and replace if necessary.
5Check poly-V-belt (1) Installation: Replace poly-V-belt (1) if necessary.
Inspect poly V-belt for wear and damage AP13.22-P-1352Z
Install
6Fit on poly V-belt (1), tension Use the Torx recess below the tensioning pulley (2) for this purpose and swivel in anticlockwise direction (arrow).
Fit on poly-V-belt (1) and slacken the tensioning pulley (2).
Do not use belt wax or any similar products.
Attach poly-V-belt according to the running diagram:
Routing diagram of poly V-beltAR13.22-P-3902-02QP
7Install wide band silencer AR09.41-P-6825T
8Close engine hoodModel 203AR88.40-P-1000P
Risk of accident caused by vehicle starting off by itself when engine is running. Risk of injury caused by contusions and burns during starting procedure or when working near the running engineSecure vehicle to prevent it from moving by itself.
Wear closed and snug-fitting work clothes.
Do not grasp hot or rotating parts.AS00.00-Z-0005-01A
9Carry out engine test run
Rasmataz
Jul 15, 2010.
