engine will not start
1994 MERCEDES BENZ 500SL
34,600 MILES
PROPICTURETAKER
  • 5 POSTS
My 1994 Mercedes Benz SL500 will not start. It has less than 35000 original miles, new battery, and new fuses. I have disconnected the battery to reset the anti theft device. I have made sure all doors, trunk and hood and gas cap are closed properly. Then I locked the car, waited a couple minutes and unlocked the car. All lights on dash come on but car won't turn over.
Aug 4, 2012 at 4:06 PM
SATURNTECH9
  • CAR REPAIR CONTRIBUTOR
  • 30,869 POSTS
Is the security light on solid or flashing?Also do you have a multimeter?
Aug 4, 2012 at 4:30 PM
PROPICTURETAKER
  • 5 POSTS
The security light is not on and does not flash. I have a multimeter that I used to check fuses prior to replacing them.
Aug 4, 2012 at 5:49 PM
SATURNTECH9
  • 30,869 POSTS
So the starter is inop correct?
Aug 4, 2012 at 7:28 PM
PROPICTURETAKER
  • 5 POSTS
I don't know. It started yesterday and now it won't. A local Mercedes Benz mechanic told me that it was a bad fuse. I don't know where the fuse is located that controls the ignition.
Aug 4, 2012 at 7:44 PM
SATURNTECH9
  • 30,869 POSTS
I need to know if the starter works or not so i can help you?Does the starter rotate the engine around?
Aug 4, 2012 at 7:49 PM
PROPICTURETAKER
  • 5 POSTS
No, the engine does not turn over at all.
Aug 4, 2012 at 8:02 PM
  • 54,354 POSTS
Hey,
Here is a awesome guide on how to fix an engine that does not start.
Please run some tests and get back to us so we can continue helping you.
Best, Ken
Feb 15, 2017 at 2:46 PM
CHEWYS
Car has sat for 2 years. It ran when parked. It will run with ether and it appears to have fuel pressure when line to fuel body is cracked. but car won't start
Feb 15, 2017 at 2:46 PM (Merged)
  • 110,190 POSTS
Check to make sure you are getting power to the injectors. You will need a noid light to do that. Most parts stores will lend them to you.
HMDTMMYWAY
2006 Mercedes 500S - it is below freezing outside and the car won't start - could it be that there is ice in the exhaust - or could it be the battery even though the key works and lights go on .. car regularly serviced with no problems - Do you think this has to do wth he extreme cold?
BMWTECHWAQAS
  • 19 POSTS
When was the last time did you change the battery? 4 years old battery def can give you issues. I would check that 1st.
HMDTMMYWAY
Thanks for responding. I had a new battery put in by the dealership last March (it is less than a year old). When the old battery required a jump, the smart key wouldn't work. Since the key works and lights go on, I don't think it is the battery. Since the car has been regularly serviced, I can only surmise that the cold weather is affecting something ( it is 3 degrees out). And - of course - I cannot afford to take it to the Dealer anymore. Any hope that it might start when the weather gets warmer? Thanks again.
Feb 15, 2017 at 2:47 PM (Merged)
BMWTECHWAQAS
  • 19 POSTS
Did you find anything with your vehicle?
CARLOSAPA
Electrical problem
1993 Mercedes Benz 500sl V8 Two Wheel Drive Automatic 149000 miles
Parked car and next day wouldnt' start. Bought a new battery,but did not solve problem. Check all fuses and they are O.K. Can I get some help. (it seems to be something simple, but I am lost). Carlos.
DOCFIXIT
  • 18,828 POSTS
Hi
When you say won't start do you mean it 's not cranking or it cranks but won't run?
CARLOSAPA
Do not crank or anything. All ligths show in dashboard.
DOCFIXIT
  • 18,828 POSTS
There are several possibilities Ignition switch, starter lockout relay, starter solenoid/motor and shift lockout switch. So to find out need to place a volt meter or test light on the starter solenoid ignition terminal turn key to see if voltage is present. Also place shifter in neutral try and start.
Let me know
MERCEDES1991
I own a 1991 Mercedes-Benz sl500 and ive recently got it running after much effort. Whenever I turn the key the engine turns over with no problem but it doesnt start every time. most of the time i have to use ether to get it started. once its started whenever i try to race the engine is dies down and makes a continuous popping sound and if i dont release the gas it with stall. please help :(
Check the fuel pressure if its within specs to rule out the fuel filter and fuel pump -start here
