1995 Mercedes Benz 300d auxillary fans
CAIRO
  • 13 POSTS
Removing the 30A relay stops the fan. Removing the 15A relay does not affect the fan. I have not located where to unplug the A/C push button control. Can you help me locate it?
Monday, April 20th, 2009 AT 5:28 PM
KHLOW2008
  • 41,814 POSTS
Removing 30A fuse means the auxiliary fans are working at high speed and the circuit should be controlled by the A/C compressor pressure switch. Test the Brown/Blue wire from relay to A/C pressure switch for shorting to ground. Unplug both relay and pressure switch to test.
Here are a description of the Push Button and auxiliary fans.
https://www.2carpros.com/forum/automotive_pictures/192750_AuxiliaryFan95MercE300_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_ACControlPanel95MerceE300_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_ACPushButtonControl_Panel_1.jpg
Tuesday, April 21st, 2009 AT 10:02 AM
