PCV valve location
RICARDOFINO
  • 2001 MAZDA MPV
  • 6 CYL
  • FWD
PCV valve location on MPV 2001 minivan.
Tuesday, August 9th, 2011 AT 11:18 AM
The PCV valve is located near the throttle body. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Cheers
Thursday, August 25th, 2011 AT 4:54 AM
SFWLR4
  • 2002 MAZDA MPV
Six cylinder two wheel drive automatic.
I am looking for procedures to replace a PCV valve on my Mazda van, specifically with illustrations.
Monday, September 24th, 2018 AT 3:57 PM (Merged)
SATURNTECH9
  • 30,870 POSTS
Here is a picture of the intake with the PCV under it let me know if that's the set up you have on your MPV.
Cheers
SFWLR4
Thanks for your response. It is an MPV LX. Brought the car in after trouble driving and the diagnosis was that it needed a new PCV hose. We have already put too much into this car over the past year and have decided to try to sell it. I thought the PCV replacement might be something I could do. I got the Mitchell online manual but could not see PCV valve/hose mentioned anywhere. Any additional guidance you could provide for the procedure/how to use the Mitchell for this would be appreciated.
Steve Fowler
SATURNTECH9
  • 30,870 POSTS
https://www.2carpros.com/forum/automotive_pictures/416332_2002_mazada_mpv_lx_pcv_location_1.jpg
It is the same one I posted on this post. It show's you where the PCV is and its hose. It say's labor time to replace it is 1.8 hours it looks like the valve is under the upper intake from what the diagram shows. Replacing the upper intake also pay's 1.8 hours. So take a look at your engine and see if you can see it under the upper intake. I found that diagram under vacuum hose routing diagram.
