Engine Misfires?
2003 MAZDA B3000
133,500 MILES • 6 CYL • 2WD • AUTOMATIC
HANKER
My truck seems to run fine until about 70 mph when it starts misfiring, causing a sudden jerk. This is particularly evident if the auto speed control is engaged. The truck then continues misfiring and slowing down until about 50 mph then usually begins running o.k. again. The problem also seems to occur when motor is under stress such as climbing a hill. Can anybody tell me what to start looking for?
Jan 23, 2010 at 5:21 PM
  • CAR REPAIR CONTRIBUTOR
This sounds like you have a spark plugs going bad but to be sure this guide will help us fix it
Jan 23, 2010 at 5:42 PM
PRW9999
The spark advance pickups may be bad in your distributor. These little plastic pieces can sometimes stick and cause your vehicle to stall while climbing a hill. Look under the plastic plate in the bottom of the distributor.
Feb 8, 2010 at 3:32 PM
HANKER
[quote:bfeb960eab="prw9999"]The spark advance pickups may be bad in your distributor. These little plastic pieces can sometimes stick and cause your vehicle to stall while climbing a hill. Look under the plastic plate in the bottom of the distributor.[/quote:bfeb960eab]
What do you look for? How do you tell if they're sticking? Are they replaceable or do you replace the distributor?
Feb 8, 2010 at 9:22 PM
BUBLHD
I had a similar problem and it ended up being the cam phaser. Unfortunately the rear end seal on the motor had gone out and the engine had gotten low on oil. this caused the bearing to go on the cam phaser and the truck started to misfire and I ended up with engine codes prior to the truck not working at all. I limped it to the dealer (a painful evolution) and a little bit of money later (thanks extended warranty) all was better.
Dec 23, 2010 at 1:56 AM
GORDYG
Engine Performance problem
2003 Mazda b3000 6 cyl Two Wheel Drive Manual
While on a road trip suddenly the engine began to missfire and knock.. The check engine light was flashing indicating miss fire and suffered a lack of power...... I drove for approx. 10 min. after as we were crossing an international boarder...... I had the vehicle towed from there..... I get no trouble codes from the OBD2...... Plug, wires , air filter , fuel filter are ok... I haven't checked fuel pump pressure or done a compression test as of yet........ Any ideas ?????? Thanks in advance.........
Aug 4, 2020 at 5:51 PM (Merged)
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
VICAUTO2
  • 41 POSTS
2001 Mazda b3000 6 cyl Two Wheel Drive Manual
Hi , I have a pick up truck Madaz 2001, manual , 81,000 miles , I have problem engines missed fire cylynder # 1 and # 3 , but did not showed code for missed fire , Engine showed code P0171 ( Cilynder #1 Bank 1 too lean ).
Sofar I have replaced new coil pack , new spark plug and wire , and new gas filter , also serviced fuel injection , I checked each fuel injection with long scop , I heard it pump and with noid light , it flashed . I also checked spark to spark plus . it 've got spark strongly . checked all vacuum hoeses did not find any leak , and spay caburator cleaner around intake manifold not any leak ,either .
I drove the truck to local auto zone , scan trouble code .
code P0171
Lean Air/ fuel ratio Bank 1
(cylinder #1 denotes Bank 1)
probale cause .
1 Low fuel pressure
2 Large vacuum leak
3Dirty/defective MAF sensor
4Engine mechanical condition .
Please , some one give me some advice , What 's problem my truck and How to fix it ? Thank you
Hi vicauto2, Welcome to 2carpros and TY for the donation.
P0171 indicates lean condition-could be one of the following below:
* Low fuel pressure due to a weak pump or leaky fuel pressure regulator. (use a fuel pressure gauge to check fuel pressure at idle)
* Dirty fuel injectors. (try cleaning the injectors)
* Vacuum leaks at the intake manifold, vacuum hose connections or throttle body. (Use a vacuum gauge to check for low intake vacuum)
* Leaky EGR valve. (Check operation of EGR valve)
* Leaky PCV Valve or hose. (Check valve and hose connections)
* Dirty or defective Mass Airflow Sensor (MAF). (Try cleaning the MAF sensor wires or filament with aerosol electronics cleaner. Do NOT use anything else to clean the sensor, and do not touch the sensor wires)
VICAUTO2
  • 41 POSTS
Hi , Sofar , I haven't got any luclk yet , I 've tried whole sunday went back and fowar to buy compressure test and fuel injection test ,It took a few trip to get a right adaptor for 2 major test , but did not fix right problem ,
I tested cilynder#1 = 150 psi
fuel pressure = 60 psi w/o engine run , 67 psi with engine run .
I cleaned MAF sensor with rubber alcohol .
and double check ignition spark cilynder # is OK.
When started engine is still same proplem , running only 4 cinlyder , cilynder #1 and # 3 misses fire , But on dasboard did not show and trouble code . I hooked up OBDII could not scan any code .
Sofar I haven't find any vacuum leak , I spayed 1 can cab cleaner around EGR valve and round lower part of intake manifold to see engine state , but not thing .
Any helps will be apreciated .
Engine misfires can also be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
VICAUTO2
  • 41 POSTS
Hi ! Thank you for quick responding . Please , some one tell me Why engine missed fire , But did not show and code ? I could not scan any codes .
VOSPIRE
My Fathers Mazda B3000 is misfiring badly. We have changed the Plugs, wires, coil pack and air filter. We ran a coder on it and it stated that 5 and 6 where misfiring. We have check the plugs and wires even though there new and we still cant find anything wrong with it.
VICAUTO2
  • 41 POSTS
hi , I removed intakemanifold again , and tracing all the hoses around it , and around the engine , But could not find any leak , checked PCV ok , It 's rattle, no stuck .
I've tested and replaced new Oxygen sensor on Bank 1 , and new upper intake manifold gasket .
It's still same problem , cylinder 1 and 3 misfired ,
Do you know any electrical relate to the problem ?
Thank you ?
Engine running rough or misfiring can be cause by the following-inspect and test all the following listed below:
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
Check no.1/3 sparkplug/compression/injector
MKRAUT
the pcm is faulty
VICAUTO2
  • 41 POSTS
Hi, Please , some one tell me where was the vacuum pump"s motor location on my Madaz V6 engine 3.0 ? Or Does it have vacuum pump's motor ?
I recently hooked up vacuum gage to intake manifold port to check how my engine vacuum .It was steady but low side about 11 in hg , It should be healthy at 15 to 20 in hg at idle speed .
The problem could be internal vacuum leaking , I could find any external leaking , the upper intake manifold gasket has been replaced new , I may change lower intake gasket , Just working around may or may not right .
Once more time , Please tell me where is my Madaz V6 engine vacuum mortor ? thank you .
VICAUTO2
  • 41 POSTS
Hi , I recently replaced IAC solonoild, PCV valve , and EGR valve , But The engine is still rough , The Engine vauum is still low , it's only 11 Hg, It should be 15 to 20 Hg for healthy engine .
All the part have been replaced , the only thing is intake manifold runer ... That the thing Engine take out side air create vauum . But engine did not show any diagnostic code , as P0171 , 0r P1512 as Intake manifold runner control (IMRC ) malfuntion ( bank 1 stuck open)
Is there any body know about Intake manifold runner , please , tell me , Thank you
No give up , be pation , keep working around .
VICAUTO2
  • 41 POSTS
HI , It would be nicer to hear different opinion than the same general technic apply for any thing . Thank you any way .
You have 2 misfiring cylinders you need to check the sparkplug, compression and injectors on those cylinders
Misfires can be caused by compression, fuel and ignition problems am sorry this is not an easy fix-proper diagnostics has to be performed, misfires can be a nightmare to remember. You need to follow up with what I've suggested earlier
