1990 Mazda B2600 Engine missing
JTC
  • 30 POSTS
I unpluged all injectors ---i have power on 1 side of plug other side of wire has nothing even when grouned with 4 injector wire where to go next? Light does not come on with tester--is wire bad?
Sunday, July 18th, 2010 AT 4:15 PM
KHLOW2008
  • 41,814 POSTS
Perform the test I posted earlier with the wire that has nothing when grounded between 1st and 4th, 2nd and 3rd.
Sunday, July 18th, 2010 AT 4:24 PM
JTC
  • 30 POSTS
I cant get to the 2nd and 3rd injectors good enought to test they are behind everything I retried several times between 1and 4 and 4 and 1 with nothing on the one side. Could a ground cable be the blame --i see a couple wires grounded to intake manifold I guess ---should I remove the short wire harness for truck to get to it easier? Oh yea thanks for all this
Sunday, July 18th, 2010 AT 4:45 PM
KHLOW2008
  • 41,814 POSTS
If 1 and 4 does not hav continuity, try using a jumper between them and retest if the 4th injector works.
Sunday, July 18th, 2010 AT 4:56 PM
JTC
  • 30 POSTS
Do I connect all iijectors back up and plug in cpu after connecting a jumper from 1 to 4 befor ei try to start motor or how do you mean test with jumper
Sunday, July 18th, 2010 AT 5:01 PM
KHLOW2008
  • 41,814 POSTS
Yes, reconnect all and start vehicle to test. If cylinder 4 starts to work, then you know the ground wire is faulty.
Sunday, July 18th, 2010 AT 5:14 PM
JTC
  • 30 POSTS
After a few test I tried to ground 4 and check from 2 and I am getting current --its 1 and 3 and 2 and 4 so now I am lost for sure--power is right if I test 2 and 4 I ground 4 and test 2 with light working so not the ground could distrubitor keep it from fireing injectors?---I did disconnect all injectors and cpu tested 1to 4 nothing tested 2 to 4 with a responce when grounded to frame light worked
Sunday, July 18th, 2010 AT 5:47 PM
JTC
  • 30 POSTS
Ok since it seems 1 and 3 and 2 and 4 are sets and 2 and 4 both arent working are we now looking at a bad cpu?
Sunday, July 18th, 2010 AT 6:58 PM
KHLOW2008
  • 41,814 POSTS
You got it wrong. 1 and 4 is a set. 2 and 3 is the other set.
You were supposed to test 1 with 4 and 2 with 3.
Monday, July 19th, 2010 AT 7:35 AM
JTC
  • 30 POSTS
I looked at wires tthe second and 4 th injectors have the same wire color the 1st and 3 have same color wires. If I ground the 4th injector and test the second I get a light when I remove ground on 4 the light goes out. The same when I ground 3 and test 1 I get light when I remove ground from 3 light goes out when I test 1 to 4 I get nothing--
Monday, July 19th, 2010 AT 9:01 AM
JTC
  • 30 POSTS
Light Green/Red wire these are the wirecolor for 1 st cylinder also same color on 3rd cylinder
Monday, July 19th, 2010 AT 9:04 AM
JTC
  • 30 POSTS
Mazda four cylinder engine error codes 1989-1994
After the engine has been operated and the key subsequently shut off, it is not necessary to restart the engine to retrieve the error codes. This is true as long as the storage battery has remained connected to the truck.
Make sure the ignition is in the "off" position. On the drivers side under the hood, on the MPV at the junction of the grill and fender there should be located a single wire as part of a small bundle of connectors. On the pickup the connector is near the firewall on the passengers side. The singe wire will have a single green connector. This wire/connector should be connected to the chassis of the truck to allow the ecm to flash the error codes.
Get in the drivers seat and turn the key to the "on" position. The check engine light should come on for a few seconds and then go out. If there are any error codes stored, the light will start displaying the codes at this time. A long flash will be for a "10" short flash for "1", eg. Code "25" will be two long followed by five short flashes. The ecm will continue to flash until all codes are displayed and then start the sequence again.
Did nothing for meand yes there is a single green plug on passenger side as stated in directions
Monday, July 19th, 2010 AT 10:11 AM
KHLOW2008
  • 41,814 POSTS
If 1 and 3 have the same wire color, then they have been swapped.
I have been telling you that cylinder 1 and 4 works in tandem. Likewise cylinder 2 and 3 are in the same circuit. If you do not wish to accept, then I have nothing more to say.
Monday, July 19th, 2010 AT 10:17 AM
JTC
  • 30 POSTS
I do need the help. Only trying to convay what I am seeing.I connected 1 to a test light with cpu unpluged and injectors unpluged and ground 4 with no result--if I ground 3 the light comes on if I ground 2 light does not come on
Monday, July 19th, 2010 AT 10:37 AM
JTC
  • 30 POSTS
At distubitor the plug that plugs into side if distrubitor.4 wires look alot those on injectors----i tested with switch on 3 wires showed power 1 none--the 3rd wire showed bright lite on tester the 2 nd 1st shows but very dim connector looks very bad
Monday, July 19th, 2010 AT 11:05 AM
KHLOW2008
  • 41,814 POSTS
If grounding #2 and # 4 works, the wires have been swapped between 1 and 2 or 3 and 4. It means the ECU is bad. Use jumper between the 1 and 2 for the ground circuit and retest. If it works, you can use as temporary measure.
Do not try to test the distributor sensor wires. Some comes from the ECU and is not 12 volt. They should be tested only with a DVOM.
Monday, July 19th, 2010 AT 11:24 AM
JTC
  • 30 POSTS
Im just list--after good inspection I unpluged wire to distrubitor and found inside crumbling apart-could bires be messing things up indide this 4 wire plug to my distrubitor
Monday, July 19th, 2010 AT 12:01 PM
KHLOW2008
  • 41,814 POSTS
The wires could be bad but if they are affecting the engine, trouble codes should be triggerred.
So prior to this, it might be intermittently failing but after you have gone through them, it could cause more problem if the wires are shorted or broken.
Monday, July 19th, 2010 AT 1:15 PM
JTC
  • 30 POSTS
Cant do much testing till I replace connector. Would you know where I could find a part like that. None in my area
Monday, July 19th, 2010 AT 1:53 PM
KHLOW2008
  • 41,814 POSTS
Internal connectors for the distributor are not shown separately. External connectors comes as a harness set.
Your best bet would be the junk yard.
Tuesday, July 20th, 2010 AT 7:08 AM
