2CarPros - Car Questions & Answers
1994 Mazda b2300 Repair Question
Topics covered: Sensor, Crankshaft, Timing belt.
Asked on April 29, 2010
Crank sensor
Engine Mechanical problem
1994 Mazda b2300 4 cyl Two Wheel Drive Automatic 80000 miles
How do you remove the Compressor/Power steering/idler pullg bracket?
Avatar Asked by popijim
Answer
Replied on April 30, 2010
need to remove PS drive belt and use pulley remover to remove pulley from pump. hold pump and rotate nut on pulley remover. remove pulley, pump from bracket then bracket.
why are you removing this for anyway? if you're replacing the crank sensor then you don't need to remove it..just remove the drive belt and crankshaft pulley. remove outer timing belter cover and rotate keyway on crankshaft to 10 o'clock position. make sure vane window of inner and outer vane cups are placed over crank sensor, remove crankshaft hub. remove sensor mounting screws and slide wires out past timing belt cover and remove sensor with wire harness retainer.
Tiny Answered by bluelightnin6 (expert)
17,236 answers provided
