Mechanics
THERMOSTAT
1998 Lincoln Town Car
Engine Cooling problem
1998 Lincoln Town Car V8 Two Wheel Drive Automatic
how do you replace a thermostat on a 98 lincoln town car
Joexray10
October 5, 2010.
Hi joexray10, Welcome to 2carpros and TY for the donation
Service and Repair
REMOVAL
CAUTION: Do not mix standard (green) coolant with Extended Life Coolant (orange). If this contamination occurs the service change interval on Extended Life Coolant will be reduced from 6 years/150,000 miles to 3 years/30,000 miles.
Drain coolant below water thermostat.
http://www.2carpros.com/forum/automotive_pictures/12900_ts1_3.gif
Remove the screw and cover.
http://www.2carpros.com/forum/automotive_pictures/12900_ts2_2.gif
Remove the bolts from the water hose connection.
http://www.2carpros.com/forum/automotive_pictures/12900_ts3_1.gif
Position the water hose connection and the upper radiator hose out of the way.
http://www.2carpros.com/forum/automotive_pictures/12900_ts4_1.gif
Remove the water thermostat and the O-ring from the intake manifold.
INSTALLATION
http://www.2carpros.com/forum/automotive_pictures/12900_ts5_1.gif
Follow the removal procedure in reverse order.
Fill the cooling system.
Rasmataz
Oct 5, 2010.
Hi
Drain some coolant then remove top radiator hose fron thermostat housing. Remove two housing bolts then housiong and thermostat.
http://www.2carpros.com/forum/automotive_pictures/198357_Graphic_639.jpg
Hope this helps
Thanks for donate
AD
Docfixit
Oct 5, 2010.
AD
