Fuel Pump Fuse
1988 LINCOLN TOWN CAR
SIERRA012105
is there a fuse for the fuel pump that can be changed out
Mar 24, 2006 at 3:42 PM
PEPPERMRJ
  • CAR REPAIR CONTRIBUTOR
  • 1,158 POSTS
[quote:dc55ea570d="sierra012105"]is there a fuse for the fuel pump that can be changed out[/quote:dc55ea570d]
It should be a yellow 20 amp fuse in location N of the interior fuse box. :)
Drivers side under the dash
see the guide below on testing fuses with a test light
See diagram below for fuse location
Mar 24, 2006 at 4:52 PM
BLOODDRAGON989
  • 7 POSTS
Electrical problem
1988 Lincoln Town Car V8 Two Wheel Drive Automatic
car was runiing great and all the sudden no fuel. I want to bypass relay but i need a diagram for the fuel relay wiring oh i forgot to mention its a limo so i really need to get it running and making money
Nov 7, 2018 at 5:33 PM (Merged)
Turn key on jump the red to orange wire on the fuel pump relay socket-did the fuel pump come on?
BLOODDRAGON989
  • 7 POSTS
jumped the wires but still no fuel guess im going to be putting a fuel pump in thanks for the help
Don't jump the gun the inertia switch is in between the relay and fuel pump bypass it and see what happens.
BLOODDRAGON989
  • 7 POSTS
Jumped switch pump still not working what else other then pump could it be
CHEVYSUV
have change comp. relays, relay plugs on ecm and fuel relays new fuel pumpno power from relay.
new ign. switch
Did you check the inertia fuel cut off switch?
Power the pump direct from the battery this will finger it
BLOODDRAGON989
  • 7 POSTS
i will give that a try i have to find the correct wires first lol
Try this at the fuel pump connector-The pink and black wire is the hot circuit and the black is ground-Good Luck
BLOODDRAGON989
  • 7 POSTS
no luck still wont kick on i but thanks for the help it is really a big help
When you apply direct power to the fuel pump it should come on-yours didin't its telling you something.
CHEVYSUV
problem started with fluel pump ran without key on over nite.
next day car ran fine. two days later car stalled no power to pump or ecm relay changed compu. ign. switch all relays and plugs.checked fuse link and fuses still no power r&r fuel pump too.
BMRFIXIT
  • 19,053 POSTS
at the fender starter solenoid has fusible links you may need to check it
you have a wiring issue
BLOODDRAGON989
  • 7 POSTS
tested power at pump connector i have 12 v at the connector on the tank pump still not powering on i have tryed my other pump with the same results what am i missing?
Check the ground side of it-something is not right-make sure you have a good ground.
BLOODDRAGON989
  • 7 POSTS
jumped ground still no luck its got me stumped
2 pumps- you best check for an open wire from the fuel pump connector to the pump
RENEE AUSTIN
how do you reset fuel relay switch
If the inertia fuel cut off switch is tripped -press the button
RICK DEWS
Engine Mechanical problem
1989 Lincoln Town Car V8 Two Wheel Drive Automatic
where is the fuel pump on the 1989 lincoln town car
Its inside the fuel tank
TIGERLILY
My fuel pump was not engaging during start up. 12v all the way to relay (30contact), 6.3v relay(87contact) and 5.2v at pump . I powered the pump directly from the battery and it works. The relay is also good, I took the same jumper I use from the pump to the battery and put it behind the relay at (87contact) and pump worked find. My question is, is it ok to bypass the fuel pump prime connector(use for factory scans) and the electronic engine control module? Both of these devices are after the relay on the same wire pk/bk leading to the pump.
Thanks
Try this and tell me if it works-At the fuel pump relay connector socket find the red and yellow wire make sure it has power jumper it to the pink and black
TIGERLILY
I tried, still not getting 12v after the relay. The pk/bk wire has resistance somewhere in the wiring after the relay(difficult to find without pulling the dash and carpet) I ran a new wire from the pump to the relay at 87(connector), cleared my fuel lines of air and the car runs great. Just afraid this might cause a future problem, because I bypassed the fuel pump prime connector and electronic engine control module. These two devices come after the relay on the pk/bk wire, on the wiring diagram.
Thanks
Fuse T and fuse no. 13 powers the EEC power relay from there it goes to the computer KAPWR circuit What color wire is at No. 87 Check power at the fuel pump cut off switch red wire Unable to read EWD below give me your email addy and I'll send it thru there.
https://images.2carpros.com/forum/automotive_pictures/12900_fuel_pump_circuit_5.jpg
TIGERLILY
Good morning,
Pk/Bk is the color of the wire coming out of contact 87 on the fuel pump relay.
The pump cut off switch has power at red wire, 12.4v key on.
No, I can not see the diagram you sent. I have to have 10 posted in order to PM you.
I don't think the Pk/Bk wire powers the EEC, it may just sent a signal. Car still runs great and the fuel mileage has increased back to normal. (Normal fuel mileage per tank is around 400miles or more on the display, before I was just getting 310mile per tank.)
Thanks
When you turn key On-Do you have power at the red and yellow wire on the fuel pump relay socket-If not you have an open with this wire between the relay and inertia fuel cut switch or the inertia switch itself-You said you have power on the red wire at the inertia switch if so and the fuel pump relay is good the fuel pump should come on.
The pink and black wire doesn't power the EEC relay. It is the wire that powers the fuel pump when fuel pump relay is energized
TIGERLILY
This forum has saved me a lot of time and money. If I would have started here, this would have been a $20 to $30 fix, instead of a $150.00:( Well lesson learned, now I know how to change a fuel pump:) Thanks!
MR.DANIELS
1996 Lincoln Town Car V8 Automatic
do you have to drop tank or is there a way threw the trunk or back seat
Jun 10, 2019 at 6:17 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
theres no access panel on this vehicle.. you'll also need a fuel tank sender wrench to remove the pump.
MRFLETCHER
HOW DO i CHECK OUT MY FUEL PUMP AND IF IT IS BAD HOW TO REPLACE IT
BMRFIXIT
  • 19,053 POSTS
check fuel pressure
check fuses and relays
check in trunk switch (
Removal & Installation (Crown Victoria, Grand Marquis & Town Car)
Release fuel pressure.
Disconnect negative battery cable. Drain fuel from fuel tank. Open fuel filler door. Remove 3 fuel filler pipe bolts. Raise and support vehicle. Remove fuel tank filler pipe from fuel tank.
Disconnect fuel pump module connector located above No. 4 crossmember. Disconnect fuel lines from fuel pump module. Disconnect vapor tube from "T" fitting on right side of vehicle. Disconnect vapor tube from canister tube. Position a support under fuel tank. Remove fuel tank support strap nuts and move fuel tank support straps away from fuel tank. Carefully lower fuel tank. Remove and discard fuel tank mounting studs.
Disconnect pressure transducer connector on top rear corner of fuel tank. Remove any dirt from around fuel pump module flange area. Remove 6 fuel pump module retaining bolts. Remove fuel pump module. Remove and discard fuel pump module gasket. To install, reverse removal procedure. Tighten fuel pump module retaining bolts in a star sequence to 80-107 INCH lbs. (9-12 N.m).
PILOTJOE50
I have 12 volts at inertia Switch, but still not getting power to fuel pump. Do not get initial power at pump to pressurize system.
Jun 25, 2019 at 6:50 PM (Merged)
  • 54,354 POSTS
Maybe you need to reset inertia switch, or that switch is faulty? At the inertia switch, Dark green wire with yellow tracer goes hot/voltage when fuel pump relay is energized. The pink wire with blue tracer should be hot, also. That is voltage from inertia switch to pump. note diagram.
Here is a guide to help you see where you loose power and check the PCM power relay that is where the fuel pump gets it power from.
Check out the diagrams (Below)
Cheers, Ken
PILOTJOE50
with key on we have 12 volts at inertia switch for about 2 seconds , then voltage goes to 3.68 volts. during this check we still have no voltage at all at the pump itself, so I replaced the PCM relay and the fuel pump started working. The car runs great! thanks :)
  • 54,354 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers, Ken
