HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Lincoln
Continental
Climate Control
Air Conditioner
Charge Port
Location
SPONSORED LINKS
AC, low pressure port location
DHARLA123
MEMBER
1994 LINCOLN CONTINENTAL
Recharging the AC. Where is the low pressure port?
Monday, May 12th, 2014 AT 5:46 PM
MECHANIC
Here is a video that shows how to find it:
https://youtu.be/ON2dYcmXIAw
and
https://youtu.be/uZrQCGwXfek
Cheers
SPONSORED LINKS
Monday, May 12th, 2014 AT 6:02 PM
WILLIAM GREEN
MEMBER
1 POST
1999 LINCOLN CONTINENTAL
V8
FWD
AUTOMATIC
59,000 MILES
Where is the A/C service ports (high side low side) located?
Tuesday, July 31st, 2018 AT 8:23 PM (Merged)
RICHZOMBIE
MECHANIC
The low side service port is located on the larger hose from firewall to the compressor. Here is a guide that will show you how:
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
Cheers,
Please
login
or
register
to post a reply.
Related Air Conditioner Charge Port Location Content
Charge Port
Where Is The Low Pressure Port Located On My Car
Asked by
dharla123
1 ANSWER
1994
LINCOLN CONTINENTAL
Ac Not Getting Cold
V8 Two Wheel Drive Automatic. Hello, I Have An Ac Problem. I Think It Is The Electronics. I Set The Controls For 60 Degrees Fan Blows...
Asked by
jimtrav1234
1994
LINCOLN CONTINENTAL
Air Conditioning Blowing Hot Air
Air Conditioning Charge Level Shows Good, Compressor Kicking On As Should, However It Is Blowing Hot Air. Any Idea's For A Back Yard...
Asked by
bud.812
10 IMAGES
2001
LINCOLN CONTINENTAL
Air Conditioning Barely Cool
Climate Control(eatc?)Does Not Have Much Effect On How Cold The A/c Gets. The A/c Low Side Pressure When Running(home Use Guage, Not A...
Asked by
snosaint
3 IMAGES
1997
LINCOLN CONTINENTAL
2000 Lincoln Continental Air Cond.
Dealer Say's I Need " A/c Manifold & Tube Assy". It Is Leaking, Part Is Not Available. They Say It Is Not O Ring. Local Garage Says...
Asked by
cmgthr
1 ANSWER
2000
LINCOLN CONTINENTAL
VIEW MORE
SPONSORED LINKS
How to Find Low Side A/C Service Port
Air Conditioner - Vacuum Down and Recharge
Air Conditioner - Add Refrigerant
Online car repair manuals
