Headlight bulb replacement
ANONYMOUS
  • 2008 KIA OPTIMA
  • 93,218 MILES
How do I replace the driver's side low beam. I've taken the dust shield off the back of the light fixture and it appears the bulb is secured by two screws and a spring affair. I cannot get a screwdriver In there to remove the screws. Is there an easier way?
Sunday, April 7th, 2013 AT 6:53 PM
  • 108,310 POSTS
It looks like you will need to remove the headlight lens to remove the bulbs here are diagrams and instructions on how to change out the headlamp bulbs. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Tuesday, February 19th, 2019 AT 6:15 PM (Merged)
JAMES 17260
  • 2007 KIA OPTIMA
  • 4 CYL
  • FWD
  • 30,000 MILES
How do you reajust the high and low beams?
Also am I looking at buying bulbs that have better out put to be able to see better?
  • 108,310 POSTS
The headlights won't need readjusted. The only time that is needed is if you have the entire assembly replaced. The bulb will not hurt the adjustment.
WYSIWYG2525
  • 2007 KIA OPTIMA
2007 Kia Optima 6 cyl Front Wheel Drive Automatic
how do you remove the headlight to replace the headlight. It is burt and I needto eplace it. Do I eed to remove the whole headlight to do ths and if so how do I do it and what kind of tools do I need to remove the headlights?
ZACKMAN
  • 4,202 POSTS
https://www.2carpros.com/forum/automotive_pictures/55316_07optimalamp1_1.jpg
https://www.2carpros.com/forum/automotive_pictures/55316_07optimalamp2_1.jpg
Just your basic screw driver.
STEVEBIGDADDY
  • 2007 KIA OPTIMA
Electrical problem
2007 Kia Optima 4 cyl
how to change lowbeam headlight
BLUELIGHTNIN6
  • 16,542 POSTS
Open the hood of your Optima. Locate the two screws on the inner corner of the headlight assembly, next to the grill area. Remove the screws with a Phillips screwdriver.
Locate the screw inside the engine compartment on the top side of the headlight assembly. Remove the screw with a Phillips screwdriver.
Pull the headlight assembly forward out of the front of the car. Pull the wiring harness connections out of the sockets. Press the retaining tabs down when you pull the connection back to release it.
Press the electrical connections into the harness connectors on the new headlight assembly. Insert the headlight assembly in the mounting area on the front of the car.
Insert the upper retaining screw and tighten it with a Phillips screwdriver. Insert the two lower retaining screws and tighten them with a Phillips screwdriver. Close the hood and test the operation of the new lights.
