Will not start when hot
2004 JEEP LIBERTY
SUNSHINE52377
six cylinder four wheel drive automatic 85,000 miles.
I drive about forty miles to pick up my son from school, if I cut the car off on a really hot day and come out to start it, it will not start for about thirty minutes. We drove to the beach and back with no problem. Have replaced battery, starter, alternator. What could it be?
Jun 21, 2010 at 3:53 PM
CARADIODOC
  • CAR REPAIR CONTRIBUTOR
  • 34,309 POSTS
Hi Sunshine52377. Welcome. To relate it to high temperature and sitting with a hot engine for a short time suggests the engine cranks but does not start up and run. A heat-sensitive, (failing), crankshaft position sensor is a common suspect but they will usually cause a diagnostic fault code to be memorized in the Engine Computer which will turn on the Check Engine light. If no code is present I would replace the engine coolant temperature sensor. because it can cause these problems as well.
Here is a guide:
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
Here is the location on your car I gave both engines.
Check out the diagrams (below)
Cheers, Caradiodoc
Jun 21, 2010 at 4:43 PM
SUNSHINE52377
I just want to thanks you my mechanic could not find out the reason, then I replaced the coolant sensor and have not had the problem since. I love this site!
Jun 25, 2010 at 4:03 PM
BPIASCIK
65,000 miles.
Car rode fine yesterday afternoon. Last night I had no power at all, I tried to jump it and now all my lights are coming on but the engine will not turn over and it is clicking.
Jun 21, 2018 at 1:35 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
Check battery terminals.
Charge and or replace battery.
JESSICASUMMER
I just changed the spark plugs also the IAC valve. It will turn over but not crank. I need help please.
  • 54,354 POSTS
If you turn the key to the on position without cranking the engine over do you hear the pump prime in the tank for five seconds?
Cheers, Ken
TAMERA89
my vehicle just will not start. Got a brand new starter. All my lights work fine. Radio plays. I took it to a mechanic and they said it was a wire. Was working fine after they fixed this wire. Then about a month later the same exact problem happen, it will not start. Had my alternator looked at, and was told it was in good condition. I had my battery looked at and was told it was also good. They recharged it, and my car started up just fine, couple hours later it would not start. Any suggestions on what could be going on?
HMAC300
  • 48,601 POSTS
Have it checked for a parasitic draw may be wearing battery down causing it.
TERRY52
Will not start. The battery is good and starter is good. Could it be the ignition switch?
ERNEST CLARK
  • 1,730 POSTS
Yes, it could be the ignition switch. But you need to follow a logical order for diagnosis of a no start.
1) Ignition system.
2) Fuel system.
3) Compression.
4) Computer/sensors/switches.
BCV2017
If the engine is cold my vehicle will not start with out me giving it gas and then I have to hold the gas until it is warm then it will finally catch. I have already had it to a mechanic and they were pretty puzzled. They said possibly a coolant temperature sensor but that usually pulls a code and their is no codes or engine light on.
CARADIODOC
  • 34,309 POSTS
Has the battery was recently disconnected or run drained? This is a common problem, and the clue is the engine runs fine as long as you hold the accelerator pedal down 1/4". Idle speed is too low because the Engine Computer has not relearned "minimum throttle". Until that occurs, the engine will be hard to start unless you hold the pedal down 1/4", you will not get the nice idle flare-up to 1,500 rpm at start-up, and it will tend to stall stop signs.
To meet the conditions for the relearn to take place, drive at highway speed with the engine warmed up, then coast for at least seven seconds without touching the pedals.
BCV2017
I have not had to jump the battery or nothing, but I will give it a try in the morning to see if it works.
BCV2017
Well I did that yesterday and it started for the first time on its own in the last three weeks. Not sure if it was just a coincidence or not. Did not start on the first crank after work but did the second time.
CARADIODOC
  • 34,309 POSTS
The easiest observation is the engine should run up to around 1,500 rpm for a few seconds after starting, then come right down to around 800 rpm. Mechanics can tell if minimum throttle has been learned by observing the automatic idle speed motor "steps" the Engine Computer has commanded it to. A scanner is needed for that. Typical for a well-running engine is step 32, (out of 256 steps). If you find it on step "0", minimum throttle has not been learned. Try doing the relearn procedure while holding the brake pedal up with your toes. If the brake light switch flickers on due to road vibrations, during the seven-second coast, that will abort the relearn event.
If you find the AIS motor is on a higher step, like 50 or more, the computer is trying to increase engine speed, but without success. That involves a different set of diagnostic procedures related to low engine performance.
RICHARD ARMANINO
V6 automatic transmission, two wheel drive with a new 12 volt battery and a new battery in remote will not start. Car was operating with no problems, then nothing happens when key turned to start position. No buzz click or anything. Put a new battery in remote. Alarm company deactivated alarm and also tried new spare remote and key. Everything running fine and then zero. When you turn key to start position no buzz click or other. Anything to try before the sending it to the crusher?
Thanks,
Richard
  • 110,190 POSTS
Are you not getting power to anything?
BCV2017
Just found out the clamp that hooks the hose on to the gas tank broke off and I was losing gas. Do you think this could be part of the problem?
RICHARD ARMANINO
Power to everything gauges, alarm, fuel pump runs on start position two fuses marked starter okay, relay?
CARADIODOC
  • 34,309 POSTS
Doubtful. There is a means of detecting leaks in the fuel vapor recovery system which would increase emissions. Chrysler does that by pumping the tank and vapor recovery lines up to two pounds of pressure, then they watch to see how long it takes to bleed down. Gas tank filler hoses usually fit pretty tightly, even without a hose clamp, so while there might have been some seepage, I suspect it was not bad enough to be detected as a leak. Had that happened, a diagnostic fault code would have been set, and the Check Engine light would have been turned on.
Even when there is a "gross leak detected", which most commonly is due to a loose gas cap, that has nothing to do with the pressurized fuel supply system for the engine. You can have the largest of leaks involving the tank, but pressure is still maintained in the supply line to the engine. It is that pressure that is needed for the injectors to work and for the engine to start and run.
  • 110,190 POSTS
There is a starter relay. Also, have you checked to make sure there is power to the starter in the start position?
RICHARD ARMANINO
Took it to a mechanic. He installed an ignition actuator and an ignition starter switch. I can see where casting broke on first piece nothing visibly wrong with second
I do not know if was a rare occurrence but parts $75.00 and labor $80.00.
Thanks for your help,
Richard
JAMIEH
Where would the clutch safety switch be located? What does it look like and would this prevent the car from starting? Could there have been an attempt to steal the car that would have put the car in some sort of security shut down?
Possibly a security issue and could also be one of the following; starter motor, starter relay, clutch switch and ignition switch.
What exactly is it doing? Cranking over and will not start or just will not crank at all/nothing when you hit the key to starting position.
JEM8888
Four Wheel Drive Automatic 64,800 miles.
Hello!
I was driving my car to the grocery store last night and when I came out my car would not turn over. It is making a loud clicking sound. Last night the radio and all the interior lights turned on and stayed on. This morning I went to try again and it is making a new clicking sound and the light are flickering on the interior. Is this my battery or alternator? I just received a new battery about two years ago. I have not yet tried to jump my car because my boyfriend is telling me it will not do anything. Should I try this first?
Jun 21, 2018 at 1:36 PM (Merged)
JDL
  • 16,098 POSTS
Hi, I would have to make sure the battery has a full charge. If not, I would take the battery off and get it charged. With the vehicle running, check the charging system.
Part of the lights and radio coming on, may have to do with your theft/security system, where applicable? Have all trouble codes checked manufacturer specific as well as generic.
ECKO566
Will not start even after running a few minutes prior. Battery and relays are good and everything electrical in the car works, but it still will not start. Any advice?
Do below to determine whether it is a spark or fuel problem.
Get a helper disconnect a spark plug wire or two and ground it to the engine, have helper crank engine over do you have a snapping blue spark? If so you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer.
2CP-ARCHIVES
  • 4,540 POSTS
Wife just got home and said she had a problem with the vehicle especially when she put it in reverse (?) but seemed okay in "drive" but was a problem again when she backed into the driveway. I went out and tried to start the vehicle to see what was wrong and had to start it twice after it conked out the first time. When I did I noticed a trace of smoke coming from underneath the hood so I immediately shut the engine off and opened the hood. When I popped the hood there was what appeared to be oil all over the engine compartment. What do I do now?
Find out why? Is the oil cap on? Is it oil?
