Images (Click to enlarge)
Dec 15, 2010 at 1:22 AM
JCOOLIDGE
MEMBER
Engine Mechanical problem
2001 Jeep Grand Cherokee 6 cyl Four Wheel Drive Automatic
where is the fuel pump located
Feb 11, 2019 at 3:53 PM
(Merged)
CAR REPAIR CONTRIBUTOR
The fuel pump is located inside of the fuel pump module.
The fuel pump module is installed in the top of the fuel tank
(Merged)
CKGKIDS4
MEMBER
I have had the fuel pump replaced 2x by a mechanic and it seems it has gone bad again. The fuel guage also quits showing correct fuel level. Is there an electrical problem causing the fuel unit to quit working and/or solution?
(Merged)
Hi ckgkids4, Welcome to 2carpros and TY for the donation
Sounds like the ground circuit black wire is open at the fuel pump connector to G200 left side of cowl-let me know
(Merged)
JEDAVIS24
MEMBER
I need to no if after I change an in the tank fuel pump to an on the fire wall fuel pump can I leave the in the tank fuel pump there or do I have to remove it.
Feb 11, 2019 at 3:54 PM
(Merged)
HMAC300
if you chagne either you shold be able to leave them where they are
(Merged)
